Toymods » Tech & Conversions » DASTEK UNICHIP - Anyone tried this ?
dispatcher
Malaysia,Kuala Lumpur
DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 07:57 Go to next message
Has anyone heard about this ? Is it any good ? OR am i better off
using haltech or E-manage etc.
Joshstix
Toymods Vice President
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 08:10 Go to previous messageGo to next message
It depends on the application. The Unichip and the E-Manage are both just piggy backs, meaning they just manipulate the signals sent to the stock ECU. This can be a good thing in situations where the operating conditions aren't that far removed from stock, because all of the niceties like idle control are still OEM quality. However on a seriously modified engine you're going to run into problems trying to bodgy it with interceptors.
The Haltech on the other hand is a complete replacement ECU. This means it controls everything. Obviously for the most modified situation this is best as it allows full control of all operating parameters. However it's also a hell of a lot more work to get it to start and run like a OEM management system.
Apples and Oranges really.
dispatcher
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 09:24 Go to previous messageGo to next message
Josh,...thanks man. appreciate it...
Also the Haltech will control individual coil packs while the other won't correct ?
Joshstix
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 09:42 Go to previous messageGo to next message
Yep the haltec can run coil packs and the piggy backs will only really do it if the original engine was running coil packs.
dispatcher
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 10:30 Go to previous messageGo to next message
Ok..time to shop for a haltech then..
Joshstix
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 11:34 Go to previous messageGo to next message
Hang on. I'm not saying Haltec is the computer that is best for your situation, just that it is the more versatile of the items you listed.
dispatcher
Re: DASTEK UNICHIP - Anyone tried this ? Mon, 04 April 2005 12:32 Go to previous message
John Thanks...I know. But Looking at squential firing order and injector cycles...and the budget. I'd say it's good enough.Unless
there's something else that you might suggest that i can compare with ?
Thank again..
Previous Topic:3T-GTE (minus turbo) vs 4A-GE
Next Topic:Audio Wire Diagram
Current Time: Thu Nov 19 10:34:02 UTC 2026
Total time taken to generate the page: 0.048057079315186 seconds
