Toymods » Members Rides » Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware)
mrsmart
Melbourne Eastern Suburbs
Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 04 April 2005 13:41 Go to next message
Well, my 6m blew its headgasket and shagged its main bearings.
After budgeting, it turned out cheaper to whack in a well priced 2jz-ge rather than repair the 6m. The 2jz-ge would be attached to other parts I had been collecting for a 2jz-gte conversion, which will still happen when the fiscal department permits purchase of an Elusive Giant Japanese Crustacean. But for now, I need cheap reliability, and that's what I'll have.
The conversion will include:
1993 supra-sourced 2jz-ge with loom and factory m/t computer,
jza71 sourced r154 (which still had a factory clutch at the time of box removal),
OS-giken twinplate clutch, with pushmepullme converter for the diaphragm spring,
and an ma61 LSD, soon to be trutrac'd (group buy permitting).
As it is, the car has an fairly average silver body, blue interior, and Koni shocks and custom 2inch low K-Mac springs all round. It also has a towbar, woo!
Photos to come very soon.
[Updated on: Wed, 06 April 2005 13:36]
Re: Ryan's JZX73... 2jz-ge Manual Cressida Mon, 04 April 2005 15:39 Go to previous messageGo to next message
Get those pics up
Re: Ryan's JZX73... 2jz-ge Manual Cressida Tue, 05 April 2005 00:54 Go to previous messageGo to next message
Sounds interesting. Pixorban.
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida Wed, 06 April 2005 08:27 Go to previous messageGo to next message
http://home.iprimus.com.au/nsmart/100_0090.jpg
http://home.iprimus.com.au/nsmart/100_0097.jpg
There is two of them two more to come...
[Updated on: Wed, 06 April 2005 13:27]
Re: Ryan's JZX73... 2jz-ge Manual Cressida Wed, 06 April 2005 08:29 Go to previous messageGo to next message
Canna see pics dude
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida Wed, 06 April 2005 08:37 Go to previous messageGo to next message
http://home.iprimus.com.au/nsmart/100_0106.jpg
http://home.iprimus.com.au/nsmart/100_0131.jpg
Here are the other two. Hope it works.
[Updated on: Wed, 06 April 2005 13:33]
Re: Ryan's JZX73... 2jz-ge Manual Cressida Wed, 06 April 2005 08:38 Go to previous messageGo to next message
Nah man, email me the pics, I'll host
Check your PM
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida Wed, 06 April 2005 13:55 Go to previous messageGo to next message
Apologies for image size, my limited PC knowledge barely stretches to MSpaint.
Engine is -as photos show- in the car. Thanks very much for the offer of help CrUZsida, I hope I've sorted it out now, if not, I'll send away.
Had a hiccup with the original starter motor, spin windings open circuit. Fitted the starter from the other 2j in the shed, problem solvered.
The clutch pedal is as heavy as buggery. Did Toyota make any smaller clutch masters than 5/8? Will I have to get this ra65 one sleeved?
All heater hoses from M were able to be re-used. They'll be fine for now.
I'm wondering about choices for primary tailshaft segment. Looks as if I'll send an a340e buttplug and uni and the original half shaft to the engineers and get them to join the bits together.
Many more pics available, engine mounts, sump to crossmember clearance etc.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Wed, 06 April 2005 14:17 Go to previous messageGo to next message
Oh, thats an R154.
Hahah, I thought it was a W58 from first inspection.
So the motor is in the same position as the 6mge was.
Yes, get the A340E yoke put onto your current tail shaft, and get it lengthed, about 80mm ish from memory.
(pics sizes are fine btw)
I'd say your clutch pedal is so heavy because thats a twin plate clutch isn't it?
But its all in the clutch.
I had a 4m clutch behind my 6m, and it was as heavy as buggery (and as weak as piss). I now have a 2200lb clutch behind the 1uz, with the same master and slave cylinder, and its like stepping on a marshmallow.
Its seriously as light as most 4cyl clutches.
Looking good though.
Post all the pics you like too, the more the merrier.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Wed, 06 April 2005 14:45 Go to previous messageGo to next message
How much of the tranny tunnel needed 'massaging' ?
I've been tempted to upgrade to R154, but undecided if its worth it.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Wed, 06 April 2005 18:54 Go to previous messageGo to next message
Nice work!
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 12:49 Go to previous messageGo to next message
Much of the trans tunnel needed massaging. It looks okay now, but it'll go for a drive tomorrow, we'll see then. MrShin did well, massaging it through various creative means- he seems to have an appetite for destruction. He will put up some pics later, he has broadband- and I don't!
The motor is quite a tight fit between the radiator and firewall. It was lucky that the gearshift lines up, especally using the auto's crossmember, bolting straight on.
The tailshaft had to be lengthened by about an inch. It's in now, fits perfectly.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 12:52 Go to previous messageGo to next message
Morepixorban!
I was surprised by how tight the front of the engine is to my radiator in the Mk2.....probably only 70-80mm....very tight for a thermo fan.
[Updated on: Thu, 07 April 2005 12:53]
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 12:55 Go to previous messageGo to next message
MrShin's got the goods -hold on- he'll have them up posthaste.
My 2j also has that closeness, we're talking an inch (if not, less) between the fan and the radiator. There's pics of that.
Of note is that the viscous fan coupling works. Another A+ for Toyota.
[Updated on: Thu, 07 April 2005 12:59]
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:04 Go to previous messageGo to next message
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20019.jpg
Dr. Shin prepares for a little work
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20021.jpg
Dig those 10 amp shoelaces!
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20022.jpg
Constant interruption by visitors..
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20025.jpg
Shinny looks at the engine mount...
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20026.jpg
...and decides to weld it. Quite revolutionary, really.
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20030.jpg
Here's what shinny would do to your backyard if he moved in...
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20033.jpg
Resident Cressida Consultant shows those young idiots how it's done...
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20036.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20037.jpg
Shinny does the washing...
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:08 Go to previous messageGo to next message
Nice work lads!
So when's it get on the road?
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:09 Go to previous messageGo to next message
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20038.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20039.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20041.jpg
Damned new-fangled jap clutch thingy. Which monkey thought of that?
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20040.jpg
You GOTTA look good when you're working on the car!
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20043.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20046.jpg
What happened after Ryan tried to, er, mount (make love to) the engine...
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20044.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20051.jpg
Man's biggest problem - Can he fit THIS...
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20055.jpg
Into THIS hole?
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:15 Go to previous messageGo to next message
We're aiming to have it on the road by early next week.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:16 Go to previous messageGo to next message
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20058.jpg
What did your mother tell you about re-using chain that is more than three times your age? This little incident was a slightly less than ideal part of proceedings... But, these things happen!
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20060.jpg
Mr Shin's leg generously gave of itself to prevent any scratches to the firewall.
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20062.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20063.jpg
The guilty mongrel! Chain link snapped in two places.
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20065.jpg
Mr Shin looks quite happy with the power steering hose. Cheap, too, and even gave an excuse to fire up the oxy.
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20066.jpg
Bloody visitors!
[Updated on: Thu, 07 April 2005 13:21]
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Thu, 07 April 2005 13:21 Go to previous messageGo to next message
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20075.jpg
It fits! One would hate to have to pull it out again, ey?
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20081.jpg
Mr Shin performs yet another of his infamous wiring jobs. Think it'll work well in wet weather?
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20076.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20077.jpg
Believe it or not, it's actually running in this pic. Damned camera is a bit quick for the fan...
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Fri, 08 April 2005 04:57 Go to previous messageGo to next message
This nasty contraction is why your clutch is so heavy!
Anyhoo, looking good.
You'll love the performance over the 6mge, plus manual just makes it so much more fun!
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Fri, 08 April 2005 21:26 Go to previous messageGo to next message
CrUZsida wrote on Fri, 08 April 2005 14:57
Are you suggesting that the 6M actually featured some kind of PERFORMANCE?? Well, I guess it WAS rather exceptional at dropping oil... er... Leaking coolant perhaps? Oooh, and smoking! Plus even Texas/Iraq would be proud of the amount of oil deposited on the underside of this car - let's just say I don't see it rusting through the floor any time soon...
BlackSupra
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Fri, 08 April 2005 21:36 Go to previous messageGo to next message
Good times lads!
2j's with no exhaust sound horn!
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Fri, 08 April 2005 23:30 Go to previous messageGo to next message
mrshin wrote on Sat, 09 April 2005 07:26
Well then you guys will be uber impressed.
<----- The Mk2 rips off a 13.8@100 with 2JZ NA powaH!!!!1111.
[Updated on: Sat, 09 April 2005 03:57]
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sat, 09 April 2005 00:39 Go to previous messageGo to next message
mrshin wrote on Sat, 09 April 2005 05:26
Hey, mine didnt leak coolant, or oil, but by god it loved to burn the shit!
And yes, you step out of a 5me auto into a 6mge manual, and the word performance does spring to mind, its all relative!
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sat, 09 April 2005 13:09 Go to previous messageGo to next message
BlackSupra wrote on Sat, 09 April 2005 07:36
Perhaps they do - well why is it that when we took it for a couple of laps of the block, that a number of people were standing out the front shaking their fists? I'm fairly sure they didn't look too happy Razz Also, I think they were a bit put out as to why on earth a Cressida was burling around sans helipad, I mean bonnet.
Grega
melbourne.victoria.austra...
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sun, 10 April 2005 00:36 Go to previous messageGo to next message
kinda reminds me of when the ute was fired up aye shinny?
nice work there fellas (except for the farkin chain)
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sun, 10 April 2005 08:22 Go to previous messageGo to next message
Put it together for a 20 minute drive today, still with no exhaust. Golly, what a note. Rear tyres attended the MrShin diet clinic.
And shoot me for saying it, but it FEELS as slow as the old 6M, though on the speedo it is actually much quicker. Luxobarge syndrome, I think they call it. I'll have to wind up the Koni's all the way- the car rides waves on gearshift.
It goes in for exhaust on Tuesday, and a few other tidbits will be tidied up through the week. Fitment of a Jaycar Digital Fuel Adjuster will be considered after a run with the EGO sensor. I'll let you few know how it goes.
Magic balancing 50 cent coin photos coming soon.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sun, 10 April 2005 08:45 Go to previous messageGo to next message
mrsmart wrote on Sun, 10 April 2005 16:22
Hahah, even the 1uz doesn't 'feel' quicker than the 6m did.
But when you see the needle climb from like 120 to 170 in 4th in no time at all, you know its a dickload faster.
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sun, 10 April 2005 14:27 Go to previous messageGo to next message
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20083.jpg
Apparently, my buttcrack is a point of fascination for Ryan. What am I SUPPOSED to do? All good workmen show crack!
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20088.jpg
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20089.jpg
Look everyone, it's the amazing balancing coin - another of Ryan's little fascinations. At least you can see the engine is running this time!
http://www.comcen.com.au/~sheehan/cressida/2JZGE%20090.jpg
Apparently, this photo is significant - personally, stuffed if I can tell the difference from before. Or was that the idea?
And before anyone pipes up, no, the air filter will NOT be left there. I'll fiddle with it a bit, tidy things up, drive it for a day or two, and see if it's happy once it gets an exhaust. Then, as said, stick the wideband in it, and see how unreasonably rich it runs. Ultimately, I think I have some kind of interest in the turbo engine going in myself Very Happy
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 00:40 Go to previous messageGo to next message
I thought you had converted to holden 5 stud?
hokey
Kilsyth, Melbourne
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 05:35 Go to previous messageGo to next message
is this ryans smarts car?
mrsmart
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 06:48 Go to previous messageGo to next message
Yes, this is Ryan Smart..Wes?
Regarding the holden 5 stud:
It would have worked. A fair while ago, I sent my HSV rotors to a highly recommended engineer to be redrilled in ford 5 stud. Ford 5 stud would be a much more sensible option, you see. Anyways, first hole the engineer drills = through reinforcement webbing. This bloke owns a large engineering business in Lilydale, and can't drill a hole in the right place. I had a bad feeling all along. Next time, I go on gut instinct.
So brakes = major setback, CrUZ. Either way, I've been offered some Brembos for a modest sum, and I insist on going against the norm, ie as big rotors as possible. With crown arms on the rear and skyline rotors on those, we'll see how she pulls up.
hokey
Kilsyth, Melbourne
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 06:56 Go to previous messageGo to next message
close Calvin his brother. i remember ages ago that you were gonna do this but i thought it was going to be with turbos attached. yeh wes drives around my red corolla you mite have seen it. Donald annoying was he? Laughing
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 07:43 Go to previous messageGo to next message
mrsmart wrote on Mon, 11 April 2005 14:48
I'm runnnig Skyline brakes on the front now.
Its only 280mm, but the 4 spots really pull it up.
Best thing is it fits under the stock rim, so new wheels are not needed straight up.
If I can find some R33 GTR calipers, I'll upgrade to the 326?mm rotors.
I highly recommend it.
BlackSupra
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 08:16 Go to previous messageGo to next message
I think you will be surprised with factory mixtures
WOT = 12.5:1 AFR
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Mon, 11 April 2005 09:55 Go to previous messageGo to next message
mrsmart wrote on Mon, 11 April 2005 16:48
Oh dear. Considering you make the average garden rake look substantial, I think you should find a better option!
I've got the 297 Nissan brakes on my Corolla. Works alright, got the bigger ones on my Sprinter, be interesting to see how well they work when she's going. Note that everything around the backyard has 5 stud wheels on it (earlier photos)
Interesting about the mixtures, and I'd hope they are somewhere there - I'll check it out tomorrow night if I get time.
September_Squall
Melbourne, Australia
March 2005
Re: Ryan's JZX73... 2jz-ge Manual Cressida (now with working pics 56k beware) Sun, 17 April 2005 14:57 Go to previous message
hokey wrote on Mon, 11 April 2005 16:56
Shocked I'm having primary school flashbacks!!!!111!!1eleven
Previous Topic:Johnny_K's Old 86
Next Topic:MX83 Cressida
Current Time: Sat Oct 17 12:02:04 UTC 2026
Total time taken to generate the page: 0.10036897659302 seconds
