Toymods » Tech & Conversions » Ignition wiring wiring for bigport 4a-g (can I use smallport parts?)
Salad Fingers
Darwin, Australia
March 2005
Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Mon, 04 April 2005 14:04 Go to next message
Hi all, i'm making a new loom for my 4a-g going into my ae86.
Im using the stock computer for now.
The only snag I have run into is the ignition side of things..
Can someone please post a pic of what the ignitor/coil looks like?
Is it a integrated unit?
Can I use an ae92 one?
what about the ae92 dissy? can I replace the entire dissy in my bigport with a ae92 one?
Reason being i can only really get smallport parts up here locally.
Grega
melbourne.victoria.austra...
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Mon, 04 April 2005 20:09 Go to previous messageGo to next message
the ae92 dizzy and ae82 (4AG) distributors are different - no you can't interchange them.
the coil and ignitor is also different on the 100kw to the 86kw but i'm not sure if they will interchange i'd doubt it.
xolent
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Mon, 04 April 2005 21:08 Go to previous messageGo to next message
i'm running 20v coil+igniter on my smallport if that helps.
shinybluesteel
melbourne
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Mon, 04 April 2005 22:20 Go to previous messageGo to next message
i was in a similar situation a while ago, i have a smallport in my sprinter, but it was running a bigport ecu, dizzy and TPS.
dizzys are different, so i got a smallport one, then got some smallport looms and ecus and made one good loom out of all the stuff.
im using an unknown ignitor and coil, and still using the bigport TPS, as they are functionally the same (different plugs)
short answer, if you change everything, you can run either engine with the other ECU.
Salad Fingers
Darwin, Australia
March 2005
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Mon, 04 April 2005 23:34 Go to previous messageGo to next message
Well thats no bloody good.
Where could I buy a new distributor cap and rotor then for my bigport dissy?
Also re the coils pack, if anyone has a pic of EITHER that would be super helpful.
Surely they cannot be that much different if you can swap ecus??
Do they have the same ammount of wires going into/out of them between the two series?
shinybluesteel
melbourne
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Tue, 05 April 2005 00:02 Go to previous messageGo to next message
ECUs are the least interchangable part of the lot, the plugs are totally different.
i learnt this the hard way,
the best thing you can do is buy a frontcut for a conversion,
next best thing, buy a complete loom with ECU and everything.
you can buy a dizzy cap and rotor from toyota, try bursons or repco or whatever, take in your old one and make sure the one they give you is the same.
as for ignitor/coil, apparently the ones from a 5ME engine work on every type of 4AGE.
injectors are not interchangable either.
Salad Fingers
Darwin, Australia
March 2005
Re: Ignition wiring wiring for bigport 4a-g (can I use smallport parts?) Tue, 05 April 2005 00:32 Go to previous message
shinybluesteel wrote on Tue, 05 April 2005 10:02
Do you know how much a cap and rotor are from toyota?
I dont have an old one.. thats the problem..
Buying a microtech is sounding like a very viable option right now though..
Previous Topic:Where to get accelerator cables made
Next Topic:7psi into 10:1 cast pistons?
Current Time: Thu Nov 19 20:55:56 UTC 2026
Total time taken to generate the page: 0.0074450969696045 seconds
