Toymods » Tech & Conversions » cold running 2tgeu
cooter
perth
cold running 2tgeu Tue, 05 April 2005 11:51 Go to next message
hey guys when i start my car it spits and splutters untill its warm. then it runs ok. its a 88261 2tgeu with 88262 injection. any ideas why this coud b? its blows a fair bit of greyish smoke when its spluttering too. please help cause im sick of having to nurse it untill it gets warm. it sometimes cant even make it up my street which is a very gradual incline.
craig
jesseT18
Castle Hill, Sydney
Re: cold running 2tgeu Tue, 05 April 2005 12:35 Go to previous messageGo to next message
warm it up! i know my engine doesnt like anything more than about 1/10th throttle till its warm
cooter
perth
Re: cold running 2tgeu Wed, 06 April 2005 00:12 Go to previous messageGo to next message
yeah but mine used to run almost the same warm as it did cold. but now it barely runs cold
cooter
perth
Re: cold running 2tgeu Thu, 07 April 2005 08:46 Go to previous messageGo to next message
bump
river
Land of Oz
Re: cold running 2tgeu Thu, 07 April 2005 12:03 Go to previous messageGo to next message
Rip out your EFI and put on some nice side-draught carbs. Then, get them tuned by someone who knows what they're doing and she'll be as sweet as pie after that. Smile
seeyuzz
river
FASTFOO
melb
February 2005
Re: cold running 2tgeu Thu, 07 April 2005 13:53 Go to previous messageGo to next message
NOOOOOOO Mad never never never ditch EFI for puddle dumpers.
it sounds like its lean thats why its worse when its cold
on an afm type efi system the most likely cause is an air leak between the afm and engine.
check all the hoses and vac pipes for leaks.
best way is to spray airostart or similar around manifold and hoses, if revs go up you found the leak Smile
hope this helps
MATT.
September_Squall
Melbourne, Australia
March 2005
Re: cold running 2tgeu Thu, 07 April 2005 14:05 Go to previous messageGo to next message
You'd get on a treat with mrshin.
Ta22lover
February 2005
Re: cold running 2tgeu Thu, 07 April 2005 18:08 Go to previous messageGo to next message
i dont know if the 2tge have cold start sensor, but it sounds like this is broke.
cooter
perth
Re: cold running 2tgeu Fri, 08 April 2005 09:28 Go to previous messageGo to next message
river: i dun wanna ditch the efi cause i plan on major upgrades. althought ive got a set of delorto 40mm sidedraughts sitting on my other engine.
Fastfoo: ok cool ill try that and see how i go.
Ta22lover: yeah i was thinking this too.
can anyone confirm if 88262 2tgeu has cold start injector?
cheers for all yur help guys. if all else fails its off to mechanic soon for valve noise fixing etc so ill get em to look at it.
craig
Ta22lover
February 2005
Re: cold running 2tgeu Fri, 08 April 2005 14:09 Go to previous messageGo to next message
i think the cold start injector/sensor is located on the intake manifoild and is usually yellow or green, you could call ur local toyota dealer and ask them about this, its usually a cheap part too, and very easy to change, so if i were you this would be the first thing i would look into.
cooter
perth
Re: cold running 2tgeu Sat, 09 April 2005 10:38 Go to previous message
hey guys i found the problem. water temp sensor was shat so i got one off my other engine and its runs good all the time again. cheers for all your help.
craig
Previous Topic:chrome strips around windows
Next Topic:how to connect an overide switch to a relay?
Current Time: Thu Nov 19 11:01:26 UTC 2026
Total time taken to generate the page: 0.0071952342987061 seconds
