Toymods » Tech & Conversions » idle problems 4ag
mrf_ool
Taree (4 hrs north of syd...
idle problems 4ag Tue, 05 April 2005 12:18 Go to next message
when it warms up at idle it revs up and then goes back down then up down up down just sits there reving up and down its a pain any hints on where to start.
79rollaboy
NSW Engadine
Re: idle problems 4ag Tue, 05 April 2005 12:21 Go to previous messageGo to next message
Idle screw, TPS...
shinybluesteel
melbourne
Re: idle problems 4ag Tue, 05 April 2005 12:27 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=63310&rid=696&S=4c768f9855f591ac21ecfefb 58358f4c&pl_view=&start=0#msg_584838
this may help you,
i have the hunting problem, check for vacuum leaks and whateber else it says in that thread
Scorpion
Menai area of Sydney
Re: idle problems 4ag Tue, 05 April 2005 13:23 Go to previous messageGo to next message
I'll vote for the idle screw in the top of the throttle body being screwed out too far. Rolling Eyes
HyDrA
Adelaide, SA
Re: idle problems 4ag Tue, 05 April 2005 14:11 Go to previous messageGo to next message
Scorpion wrote on Tue, 05 April 2005 22:53
Me too... my ISCV was stuck open and I had this (AFM 1G-GTE however)
mrf_ool
Re: idle problems 4ag Tue, 05 April 2005 21:38 Go to previous messageGo to next message
its screwed right in and it still idles at about 1400 rpm.
monkeymajik
Re: idle problems 4ag Tue, 05 April 2005 22:01 Go to previous messageGo to next message
leak then?
Matt-AE86
Re: idle problems 4ag Tue, 05 April 2005 22:55 Go to previous messageGo to next message
Have you got the coolant pipes to the intake connected ? I have heard of someone with same problem as yours, they then found they had a blockage in that area, and i think it went back down.. But then others say you dont need them connected. I will see when I fire my engine up.
Re: idle problems 4ag Tue, 05 April 2005 23:51 Go to previous messageGo to next message
Auxilliary Air Valve.
Read: http://www.toymods.org.au -> Tech Docs -> 4AGE Book -> EFI -> Pages 84 onwards.
When the wax pallete in these things go, what you are experiencing is the common symptom.
ALL your answers on how the AAV works are right there.
towe_001
Somewhere on a dirt bowl ...
Re: idle problems 4ag Wed, 06 April 2005 00:00 Go to previous message
I've had this prob more times then you can count on two hands.
First time was when i flushed the system and refilled it i didn't get all the air out of the block.
Second time was of a split hose around the water pump.
Third - loose connection on the water pump.
Fourth - loose bottom hose.
Fifth - Split hose at the throttle body. I used the other hose as a bridge. So much for that idea Rolling Eyes
I can keep going...
But really its to do with the temp sender thats at the gearbox end of the head. If the coolant level is lower then what the temp sender is, you'll get the hunting idle. OR, if you don't have the coolant going to the TB you'll get the same thing.
Previous Topic:AE82 4AGE Electric Thermo Switch ??
Next Topic:Blown Head Gasket Symptoms on 2T Celica?
Current Time: Sun Oct 18 21:00:08 UTC 2026
Total time taken to generate the page: 0.006058931350708 seconds
