Toymods » Tech & Conversions » Methods to unscrew a nut that doesnt move
terrykoun
Methods to unscrew a nut that doesnt move Wed, 06 April 2005 03:10 Go to next message
hey this isnt really that technical and maybe shouldnt be in this section. But anyways, you guys must have run into this problem at least once in ur lives. How do you loosen a nut that wont budge. Besides a screwdriver and a hammer and wd40 what other methods are there?
setsuna
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 03:21 Go to previous messageGo to next message
vice grips?
a BIGGER hammer and a chisel?
river
Land of Oz
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 03:26 Go to previous messageGo to next message
WD40 works, but you gotta give it some time. If that doesn't work you can try heating the nut and hope it will expand enough to loosen a bit. If it's a little nut you may be able to use a pair of sidecutters or pincers to grab the nut, dig into it a bit, and free it.
If it's a large nut then you can angle grind it on two opposing sides (assuming you can get the grinder into place) and this gives you extra purchase for a wrench of spanner.
seeyuzz
river
Henn
Rosanna, Melb
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 03:32 Go to previous messageGo to next message
Weld a good length of bar onto the nut. Lean on the bar. Watch as either the nut comes off or you snap the stud. Either way it's off.
Hen
davedave
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:04 Go to previous messageGo to next message
Try some penetrant rather than wd40, repco or somewhere will sell it.
Other mentioned methods that I've had good results with are
hammer it: give it a whack, helps free stuck things
heat it: give it a blast with an oxy or something, but not too much as the idea is to expand the nut but not the bolt.
extend it: the longer your tool, the more leverage (power) you have
Try not to do this Confused
http://home.swiftdsl.com.au/~mk15/index.php?image= IMGP1082_800.jpg
[Updated on: Mon, 02 May 2005 07:37]
urban_myth
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:38 Go to previous messageGo to next message
i reckon some vicegrips and one long arse pipe to turn it if you got the space, otherwise just hit the visegrips with a hammer to turn them
davedave
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:47 Go to previous messageGo to next message
I tend to like sockets over spanners/vice grips/nut f*ckers(shifters) for tight nuts. As it applies force to 6 corners of the nut as opposed to two, and hence tends to strip the bugger a lot less.
Jorrs
Coffs Harbour
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:48 Go to previous messageGo to next message
get a drill and drill deep in to the middle of it and it will come out Smile
MR 1JZ
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:51 Go to previous messageGo to next message
Jorrs wrote on Wed, 06 April 2005 15:18
you would be suprised that actually can fuck things up a lot worse Sad
Allan
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 05:52 Go to previous messageGo to next message
the gas axe AKA oxy torch AKA many other things is fantastic, you just heat up the nut and most of the time you can blow the nut off without killing the bolt or if your really shitty blow the whole thing off and wack a newie in in about 5 seconds... takes longer to drag the bottles out!
TheStitt
Membership Secretary
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 08:16 Go to previous messageGo to next message
Penatrant is awsome stuff give a sec or two to get in there.
Some times tightening a little can loosen it. It works with screws never had to do it on a nut.
Leveage is also the the big thing bits of pipe on the breaker bar work wonders
rollin_stock
February 2005
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 08:43 Go to previous messageGo to next message
use a Impact wrench, like a impact screwdriver but with a socket end! Invest in one, they are great when taking body panels off where the head of the bolt rounds out easily or the thread is rusted in the body. They arent very expensive and worth the money, i use mine all the time.
Joshstix
Toymods Vice President
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 08:47 Go to previous messageGo to next message
Nutsplitters are pretty handy things for this at times.
http://www.diytools.co.uk/diy/Images/DB_100_100/TB_28704.jpg
styler
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 08:53 Go to previous messageGo to next message
well from easiest/simplest tools to most difficult,
get some penetrant onto it and use ring end of spanner to apply
force whilst hitting with hammer. sockets are on the wrong plane
and wont do it if its really tight.
impact wrench if you have one
use a nut splitter, about 10 bucks from tradetools or
grind it off if you can do it without grinding anything else lol.
iv never tried heating it but have heard of it
weld a bar onto it and turn it
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 09:31 Go to previous messageGo to next message
Henn wrote on Wed, 06 April 2005 13:32
Henn has a sense of style. Laughing
takai
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 09:34 Go to previous messageGo to next message
Angle grinder, preferably 12" or larger.
devolutio
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 12:04 Go to previous messageGo to next message
davedave wrote on Wed, 06 April 2005 15:04
I'm so lame Razz
checks202
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 16:01 Go to previous messageGo to next message
The good old 25inch long bar gives the leverage. If all else fails grind the thing of and keep the thread so you know what to get when getting a new. Smile
styler
Re: Methods to unscrew a nut that doesnt move Wed, 06 April 2005 17:14 Go to previous messageGo to next message
ah or use a persuader, ie a long pipe which the spanner
will fit in to. iv used mine a few times, its about a metre
long.
davedave
Re: Methods to unscrew a nut that doesnt move Thu, 07 April 2005 00:17 Go to previous messageGo to next message
devolutio wrote on Wed, 06 April 2005 22:04
I'm so lame Razz
Sorry to hear dude, many other guys are blessed with long tools either Twisted Evil
terrykoun
Re: Methods to unscrew a nut that doesnt move Thu, 07 April 2005 04:21 Go to previous message
yea sweet ill try the penetrant. Ive tried the leverage bar but its no good. In the end i reckon the nut splitter will be the easiest,.
Previous Topic:panel filter suit ae92???
Next Topic:Engine temp too low?
Current Time: Fri Nov 20 22:54:49 UTC 2026
Total time taken to generate the page: 0.0080680847167969 seconds
