Toymods » General Car Talk » Best CA20E motor?
SilverGhost
Best CA20E motor? Wed, 06 April 2005 08:45 Go to next message
I have a pintara with the CA20E twin ignition (8 plug) motor as a back up car. Now the motor is showing its age with rhythmic surges of power and various other symptoms.
Im looking for the model of car which had the 'latest gen' of the RWD CA20E motor as it were, so that i can price a halfcut and do a swap.
As i understand it there are vacuum advance style motors (mine Mad ) and electric advance style motors, also single spark variants.
Does anyone know what pintara/pulsar/gazelle has the latest model CA20E? and what hardware does that motor come with?
thanks!
ae95
Re: Best CA20E motor? Wed, 06 April 2005 10:42 Go to previous messageGo to next message
why not go ca18det?
Re: Best CA20E motor? Wed, 06 April 2005 11:02 Go to previous messageGo to next message
R31 pintara's had the last model CA20E.
I think its 89ish before the change over to FWD.
I converted my mates to CA18DE from a Silvia. Bolts in, just need the silvia flywheel.
SilverGhost
Re: Best CA20E motor? Thu, 07 April 2005 02:29 Go to previous messageGo to next message
really? bolts in?
you mean you got a whole ca18de and threw it in, not bolted a ca18 head on the ca20 block...
so if i wanted a rwd ca18de id get like a half cut from a 180sx, or an s13?
Re: Best CA20E motor? Thu, 07 April 2005 02:40 Go to previous messageGo to next message
Yeah man, CA18DE block.
I'm 90% sure we used the CA20E aircon unit, but I can't remember.
We used the CA20E engine mounts, they bolted to the CA18DE block.
The exhaust was too short by 100mm or so, but it only cost $50 to get a bit made up.
The wiring was the hardest bit as it was my first attempt.
The CA20E fuel pump is constant earth, and 12v switched.
The CA18DE is constant 12v, and earth switched.
Took about 4 days to figure that one out.
Tacho still doesnt work, as it needs a booster (CA18DE is coil pack)
We didnt use the temp sender from the CA20E so the temp guage is a bit off (I'm not even sure if they have a separate guage and ecu sender like Toyota's do)
The CA20E uses a 6 bolt flywheel, and the CA18DE uses an 8 bolt.
The CA18DE we got was an auto, so we had to source a flywheel, and a new clutch.
Don't forget to put in a spigot bush if you do the same!
Throttle cable is on a bit of an angle, but its been like that for a couple of years now, and its fine. It even went over the pits like that.
I think thats the main differences.
I do recommend changing the water pump, timing belt while the motor is out too. The water pump is off the timing belt, so its a bitch to replace while in the car.
Get the injectors cleaned and give the coilpacks a nice cleaning with CRC too.
And it was from an S13 Silvia.
HyDrA
Adelaide, SA
Re: Best CA20E motor? Thu, 07 April 2005 08:50 Go to previous messageGo to next message
Put in a toyota motor Razz
SilverGhost
Re: Best CA20E motor? Thu, 07 April 2005 09:34 Go to previous message
believe me im tempted...the r31 engine bay screams for a 1jz, but as its my backup car (ie the one that you want to spend the least on) a straight bolt in job would be best....
i was first tempted just to rebuild the motor myself...but this motor comes with a vacuum advance unit that keeps failing due to age....and i can only find good replacements from wreckers for so long, hence i was wondering what model had the single spark and electrically controlled ignition. cause i have seen them out there and think they would be the better option...
thanks for all your input btw guys!
Previous Topic:Simon's Photoshop challange
Next Topic:cry for help
Current Time: Sat Oct 17 16:36:04 UTC 2026
Total time taken to generate the page: 0.0047781467437744 seconds
