Toymods » Tech & Conversions » TA22 struts into KE20
kehamer
TA22 struts into KE20 Wed, 06 April 2005 09:16 Go to next message
Can anyone tell me in a little detail the steps in putting ta22 struts into a ke20. im hopefully attempting this in the near future. From what i gather, there are some modifications needed to the control arm? thats about all i got. any help appreciated
james
kehamer
Re: TA22 struts into KE20 Wed, 06 April 2005 22:38 Go to previous messageGo to next message
anyone know??
Ronin86
ADELAIDE
March 2005
Re: TA22 struts into KE20 Sun, 10 April 2005 05:39 Go to previous messageGo to next message
i'm interested to know this my self , i can't help much but i was at the wreckers and looking at the front strunts of a ra23 or something like that and there was a ke30 corolla next to it ,and that got my thinking if the the strut would fit into my 25 cos the strut in the 30 are simlar, i was thinking of just thinking of trying to fitting the brakes to the ke20 strut instead
sorry not much help but hope if there is more reply some may help
kehamer
Re: TA22 struts into KE20 Sun, 10 April 2005 11:16 Go to previous messageGo to next message
funny i got a reply tonight, cause today i started the conversion. me and my mates got as far as getting the strut out, but the ta22 steering knuckle is also needed, which i didnt purchase with the strut... so hopefully some better luck tomorrow, as we all have the day off work Very Happy . We discovered some mcool dodgy work of lowering the previous strut though Confused I fanyone knows anything else thatll stump the swamp other than the steering knuckle/ball joint, please let me know...
towe_001
Somewhere on a dirt bowl ...
Re: TA22 struts into KE20 Mon, 11 April 2005 15:47 Go to previous messageGo to next message
Sweet ! Post how it all goes
Any chance on maybe pixs as well ?
Super Jamie
On Probation
North East NSW
Re: TA22 struts into KE20 Tue, 12 April 2005 06:39 Go to previous messageGo to next message
you can find a list of steering arms and what struts go on what steering arms over on toycrazy.net. you need to swap the strut and steering arm onto the ke20 lower control arm, and retain the ke20 strut top
you'd have to play around with springs, as ta22 springs would probably be too high for a ke20. you could also convert to weld-on height adjustables which would need to be engineered
ta22 springs may be too large in diameter to fit in ke20 strut towers. i know ke20 and ke70 have smaller diameter springs than ke30/55, which i assume would be the same as ta22
i'd say you'll then need to upgrade the brake master cylinder, as ta22 brakes are alot bigger
kehamer
Re: TA22 struts into KE20 Tue, 12 April 2005 08:19 Go to previous messageGo to next message
The conversion is pretty much complete... jamie wasnt far off from wat we did, but we used the whole ta22 control arm and the strut. The ta22 strut tops were replaced with the ke20 ones and the springs swapped over too, as they were too wide for the strut tower. My springs had been cut by the previous owner, so im just going to get pedders to install all new shocks, springs and itll need a wheel alignment pretty bad before engineering.
The only real mods it needed was widening of the 2 holes for the strut bar, as on the ta22 they are all of a couple of mm's too far apart. To connect the strut bar to the control arm, i had to shorten it as much as i could...still hoping it wont have to be replaced when i get it aligned.
any questions, just ask.. cause even i hope i can answer them
Super Jamie
On Probation
North East NSW
Re: TA22 struts into KE20 Wed, 13 April 2005 06:29 Go to previous message
interesting, did the ta22 control arms bolt up to the ke20? was there much difference in length? have you noticed the steering slower with the longer ta22 steering arms?
for what it's worth, both installing different struts into any car, and modifying a suspension component (such as a control arm) is illegal, so you technically shouldn't be able to get either of those certified. your engineer might be a good bloke though, good luck Smile
[Updated on: Wed, 13 April 2005 06:29]
Previous Topic:Sway bars?
Next Topic:aw11 engine light
Current Time: Mon Nov 2 09:48:41 UTC 2026
Total time taken to generate the page: 0.08365797996521 seconds
