Toymods » Tech & Conversions » 1G-GZE vs 1G-GTE valves
Dominic
Perth,western australia
1G-GZE vs 1G-GTE valves Thu, 07 April 2005 06:30 Go to next message
does any one know if GTE valves are bigger/same size as GZE valves?
also does anyone know of an over size piston that will fit the 1G-GZE?
just wanting try and up the cc's on the 2lt.
i know about the HKS stroker kits but they are hard to find and cost a F#*k load...not that boring and custom forgies is any cheaper really...but still if any one knows of anything id much appreciate it.
Dom
Dominic
Re: 1G-GZE vs 1G-GTE valves Thu, 07 April 2005 12:14 Go to previous messageGo to next message
well,
through some more trawling of the arhcives via the search function ive found a few referance's saying that the comp ratio in the GZE is 8.0:1 and the GTE is 8.5:0.
and other than that the internals are the same.
Dom
TerryOBeirne
Redbank Plains,near Ipswi...
Re: 1G-GZE vs 1G-GTE valves Thu, 07 April 2005 12:43 Go to previous messageGo to next message
the valves are the same size but I can usually get 1mm and 1.5mm oversized , race spec stainless ones. i had to get special forged pistons last time we did one of these, where the owner wanted a capacity change
Fattony
Re: 1G-GZE vs 1G-GTE valves Fri, 08 April 2005 00:22 Go to previous messageGo to next message
Dont know the if this works but i head that 4agze pistons fit and can make the motor bigger. Just a rumor i heard, if some1s willing to find out if this works all be it Smile
Dominic
Re: 1G-GZE vs 1G-GTE valves Fri, 08 April 2005 02:27 Go to previous messageGo to next message
who makes teh valves?
and when you changed teh capacity how did you do it?
borre or stroke?
if bore what pistons etc did you use who made them etc
Dom
gold28
Madrid - Spain
Re: 1G-GZE vs 1G-GTE valves Fri, 08 April 2005 03:17 Go to previous message
I know some parts are interchangeable between 4a and 1g (valve stem seals), but I would have thought that the 4a pistons would be a fair bit bigger.
Anyone know what diameter thay are? I think the 1G ones are 75mm. I thought the 4a ones were closer to 80mm. That wouldn't leave you with much wall thickness on your cylinders.
Previous Topic:Squealing noise from front wheel?
Next Topic:4AGE aftermarket computers
Current Time: Sun Oct 25 09:20:24 UTC 2026
Total time taken to generate the page: 0.0041079521179199 seconds
