Toymods » Tech & Conversions » w5X shifter positions. interchangable???
people100
Rocklea qld
w5X shifter positions. interchangable??? Thu, 07 April 2005 07:30 Go to next message
can the rear housing (shifter postion and gearbox mount) be taken from a w55 gearbox and put on a w50. reason im asking is my mounts have been made to bolt my engine but when it was measure the gearbox was bolted to the wrong holes underneath the car. looks like if i use the w55 one ( has a w50 in it now) it will move the crossmember back to line up with the right holes.
Re: w5X shifter positions. interchangable??? Thu, 07 April 2005 07:58 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=26418&rid=4164&S=0ef1ac68636c376d4230d12 3c5d86d80&pl_view=&start=0#msg_num_17
CrUZsida wrote on Mon, 05 January 2004 14:55
OK
W40/50 share the same bellhousing
W57/58 share the same bellhousing
w40/50 bell/h is not compatible with w57/58
They are the same length, thus no tailshaft mods
The Xmember position is approximately the same (few mm from memory) so doesnt require any xmember mods
W40/50 shifter positions are interchangeable
W57/58 shifter positions are interchangeable
w40/50 shfiter is not compatible with w57/58
Shifter positions are available almost anywhere for both boxes, depending on which car they came from.
Anything else?
[Updated on: Thu, 07 April 2005 07:59]
ra23celica
Re: w5X shifter positions. interchangable??? Thu, 07 April 2005 08:03 Go to previous messageGo to next message
Enuff said !
people100
Rocklea qld
Re: w5X shifter positions. interchangable??? Fri, 08 April 2005 10:07 Go to previous messageGo to next message
yes. but what about w55. i guess thats is only interchangable with w57???
Re: w5X shifter positions. interchangable??? Fri, 08 April 2005 10:12 Go to previous messageGo to next message
Parts are interchangeable between W55/56/57/58/59, they're pretty much the same box.
Re: w5X shifter positions. interchangable??? Fri, 08 April 2005 10:53 Go to previous message
The W55 is just a W57 with different gear ratios.
Its the same box.
Its impossible to tell from the outside what you have.
Previous Topic:How to tell if radiator is triple or double core
Next Topic:4cyl vs 6cyl in ta22?
Current Time: Sun Oct 25 19:05:57 UTC 2026
Total time taken to generate the page: 0.004706859588623 seconds
