Classifieds » Engines, Accessories and other Mechanicals » prepped 88270 18RG head, 18RGEU series, NEW PICS
Mr DOHC
prepped 88270 18RG head, 18RGEU series, NEW PICS Thu, 07 April 2005 08:06 Go to next message
my workmate has a prepped 88270 head for sale, it has TRD valves, dual springs {not sure whether they are std or not, can have them tested tho if interested}.
Not sure if it has been ported as there is some carbon deposits in the ports {will look on monday},
it came off a hi compression big bore engine that shit a piston {did the ringlands}, no damage to the head, just put in an 18RGU instead.
lumpy cams can be suplied for a price too.
Looking for $350
[Updated on: Sun, 17 April 2005 20:08]
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Thu, 07 April 2005 11:39 Go to previous messageGo to next message
will also be getting either a 88250 or 88253 head too, it has bent valves, might be able to do a deal too.
[Updated on: Thu, 14 April 2005 06:50]
TurboRA40
Melbourne's East
March 2005
Re: prepped 88270 18RG head, 18RGEU series Mon, 11 April 2005 12:39 Go to previous messageGo to next message
Any Idea of the duration or lift of the big cams? I might be interested if you'll sell them separate.
Glen
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Mon, 11 April 2005 12:42 Go to previous messageGo to next message
i can work out lift tomorrow, cant work out duration tho
to give u some idea, they are to suit a hi comp 92mm bore carbie engine pulling a fat arse car {4 runner}, so they made some alright power
Steve M
Re: prepped 88270 18RG head, 18RGEU series Tue, 12 April 2005 14:55 Go to previous messageGo to next message
Hey Phil,
Can you give me a bit of a report on the head?
Valve sizes
Port enlargement and quality of port job
valve springs (not hugely fussed, planned upgrade anyway)
corrosion present
once that comes through, if that all looks good enough I would buy, pending basic light pressure test to find if cracked.
I realise this may be asking a lot, but we have already got one ported head with a ten inch crack in it, don't really need another spare!
You could email me if that's easier for you, or PM is fine too.
mcostalos
Adelaide, South Australia
February 2005
Re: prepped 88270 18RG head, 18RGEU series Tue, 12 April 2005 14:59 Go to previous messageGo to next message
If i have to buy the head in order to get the valve, then lets do it.
Let me know.
Michael
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 08:10 Go to previous messageGo to next message
have pics, have specs
head IS an 88270 head {EFI}
engine was running, broke ringland so a stock fresh 18RGU was put in instead.
has had port job on both intake and exhaust sides, has TRD valves on both inlet and exhaust, has HUGE cams, has been running on optimax, as u can see from the cleanliness of the intake port {the rumours about the optimax cleansing are true}, i have not touched the inlet ports, or tried to clean them in anyway
VALVES
Valves are TRD, inlet is 47mm{1.85"}, normally they are 45mm, exhaust are 40.5mm{1.6"} normally are 39mm
PORTS
Porting looks to be extensive, very high quality, {compare the std 88270 pic to the ported one, gave the exhaust port a bit of a run over with the fine wire "wheel" to get rid of some of the carbon, u can also see that its ported too.
CAMS
cams are a base grind,
Intake part number is 124E, {might be wade grinds} has a gross lift of 442"{11.42mm} net of 432' {10.97mm},
Exhaust part number is 166, has a gross lift of 475" {12.06mm} and 465" net {11.81mm}
gross std lift on 88270 cams are 10.3mm for the intake and 9.7 for the exhaust
pics below are of the ported head
http://forums.toymods.org.au/index.php?t=getfile&id=11132
http://forums.toymods.org.au/index.php?t=getfile&id=11133
http://forums.toymods.org.au/index.php?t=getfile&id=11134
Attachment: inport1.jpg
(Size: 38.51KB, Downloaded 158 time(s))
Attachment: inport2.jpg
(Size: 58.11KB, Downloaded 157 time(s))
Attachment: exhport1.jpg
(Size: 54.74KB, Downloaded 153 time(s))
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 08:12 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=getfile&id=11135
http://forums.toymods.org.au/index.php?t=getfile&id=11136
the pic below is of a standard 88270 head's intake port,
http://forums.toymods.org.au/index.php?t=getfile&id=11137
Attachment: exhvalve.jpg
(Size: 68.83KB, Downloaded 140 time(s))
Attachment: invalve.jpg
(Size: 95.17KB, Downloaded 141 time(s))
Attachment: std270.jpg
(Size: 36.99KB, Downloaded 138 time(s))
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 08:13 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=getfile&id=11138
http://forums.toymods.org.au/index.php?t=getfile&id=11139
Attachment: front.jpg
(Size: 50.76KB, Downloaded 137 time(s))
Attachment: whole.jpg
(Size: 96.61KB, Downloaded 137 time(s))
mcostalos
February 2005
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 08:47 Go to previous messageGo to next message
That second TRD valve doesn't look too good.
What do you think?
Michael
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 09:23 Go to previous messageGo to next message
the valves are fine, had a nice layer of carbon on it {as most exhaust valves do}, so i gave it a hit with the wire wheel so the word TRD could be read, once cleaned up properly i will be prefectly
Steve M
Re: prepped 88270 18RG head, 18RGEU series Wed, 13 April 2005 12:47 Go to previous messageGo to next message
Oops, I just sent you a message asking for the pics that you just posted up.
I sent you the sets of cam profiles a minute ago.
After seeing the photos, all questions are answered, I want that head!
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Thu, 14 April 2005 09:34 Go to previous messageGo to next message
here are the pics of the water ports, i havent tried to clean them up tho
the one below is of one of the water drains, the black/brown deposits are the headgasket glue, not corrosion
http://forums.toymods.org.au/index.php?t=getfile&id=11177
this one is of where the thermostat housing bolts to, see theres no corrosion what so ever, that is gasket paper around the outside too.
http://forums.toymods.org.au/index.php?t=getfile&id=11179
this is one of the water feeds to the inlet manifold, has some very minor corrosion, negligible really
http://forums.toymods.org.au/index.php?t=getfile&id=11180
Attachment: gal1.jpg
(Size: 99.63KB, Downloaded 121 time(s))
Attachment: gal2.jpg
(Size: 118.88KB, Downloaded 119 time(s))
Attachment: gal3.jpg
(Size: 103.57KB, Downloaded 115 time(s))
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Thu, 14 April 2005 09:36 Go to previous messageGo to next message
this is a pic of the top of the head, best part is, this head only went thru the washer for like 10 mins, and it was up the other way, the water didnt even hit this side.
clean huh Very Happy
http://forums.toymods.org.au/index.php?t=getfile&id=11181
Attachment: whole2.jpg
(Size: 99.62KB, Downloaded 112 time(s))
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Thu, 14 April 2005 09:37 Go to previous messageGo to next message
oh yeh, u also get the 2 guides shown
Steve M
Re: prepped 88270 18RG head, 18RGEU series, NEW PICS Thu, 14 April 2005 13:47 Go to previous messageGo to next message
Sure does look good to me!
Those shims must be monsters, is there actually anything left of the base circle on those cams?
We are currently running base circle regrinds and the buckets are not as far out as those ones are. My guess on shim thickness there is about 4.5mm.
Doesn't make too much difference to me though, will be going back to STD 88270 cams and shims for the turbo project.
M.J.H
Re: prepped 88270 18RG head, 18RGEU series, NEW PICS Fri, 15 April 2005 06:25 Go to previous messageGo to next message
PM sent.
Any idea on what power the engine was making.
What sort of comp ratio was it running?
TurboRA40
Melbourne's East
March 2005
Re: prepped 88270 18RG head, 18RGEU series Sun, 17 April 2005 01:03 Go to previous messageGo to next message
Cool I'm interested in the big cams if you want to sell them separate. How much were you looking for them?
Glen
Mr DOHC
Re: prepped 88270 18RG head, 18RGEU series Sun, 17 April 2005 20:08 Go to previous messageGo to next message
cams are still for sale $250
TurboRA40
Melbourne's East
March 2005
Re: prepped 88270 18RG head, 18RGEU series Sun, 17 April 2005 22:15 Go to previous message
PM sent
Previous Topic:RWD 3sg to supra bellhouse
Next Topic:1JZ stuff that came with the car...
Current Time: Mon Oct 19 17:52:21 UTC 2026
Total time taken to generate the page: 0.006054162979126 seconds
