Toymods » Tech & Conversions » 3T-GTE no injector pulse!!help!!!
freakincage_com
north brisbane
3T-GTE no injector pulse!!help!!! Thu, 07 April 2005 08:39 Go to next message
ey guyz i have my engine n box n everythin in my car now!!!!itz getting somewhere!!!but it wont start,,help!!!i got fuel and i got spark, n i can manually activate the injectors,,,,but no pulse wen itz al conected...
FASTFOO
melb
February 2005
Re: 3T-GTE no injector pulse!!help!!! Thu, 07 April 2005 14:23 Go to previous messageGo to next message
Earth cable from engine loom to inlet manifold not conected
Thats my guess. Smile
MATT.
freakincage_com
north brisbane
Re: 3T-GTE no injector pulse!!help!!! Sat, 09 April 2005 04:02 Go to previous messageGo to next message
it is....
berad
Re: 3T-GTE no injector pulse!!help!!! Sat, 09 April 2005 08:02 Go to previous messageGo to next message
so can u manualy make ther injectors pulse, maybe they have jammed up...
standard ecu
aftermarket?
freakincage_com
north brisbane
Re: 3T-GTE no injector pulse!!help!!! Sat, 09 April 2005 09:17 Go to previous messageGo to next message
yer i can manualy activate them....standard ecu....
Re: 3T-GTE no injector pulse!!help!!! Sat, 09 April 2005 12:25 Go to previous messageGo to next message
ECU not getting a signal from the coil/igniter?
ECU not getting power when you're cranking the engien to start it?
bad earth somewhere - check your wiring again - visually and with multimeter
berad
Re: 3T-GTE no injector pulse!!help!!! Sat, 09 April 2005 13:35 Go to previous message
haVE U checkd the contunity of the wires from ecu to injector plug?
aka put the multimeter on logic and test if the wires are broken or bad connection?
probably not the problem but worth a try
i dont know about standard ecu's but my ecu will still pulse the injectors if it isnt getting signal from the ignition system
as my car wont start atm as, ignition is not working properly but the spark plugs are getting soaked in fuel
[Updated on: Sat, 09 April 2005 13:44]
Previous Topic:AFM maximum measuring capacity calc (flap-type)
Next Topic:White Smoke at idle
Current Time: Thu Nov 19 09:31:07 UTC 2026
Total time taken to generate the page: 0.0054469108581543 seconds
