Toymods » Tech & Conversions » turbo oil and water lines
kewp
wollongong
turbo oil and water lines Thu, 07 April 2005 10:58 Go to next message
If you doing an aftermarket turbo conversion, where is the best place to buy oil and water lines? How much would it be to have them custom made, or is it better to find the standard ones that came on the car the turbo is off?
Also is this a good way to hook up the oil lines:
T-piece on oil pressure warning light --> turbo oil inlet --> turbo oil outlet --> oil cooler --> sump
Or would it be better to put the oil cooler before the turbo?
STR8 2.8
Re: turbo oil and water lines Thu, 07 April 2005 11:25 Go to previous messageGo to next message
just go to pirtek/enzed etc.
if its an aftermarket conversion, chances are the original lines wont work anyway.
it wont be cheap though.
[Updated on: Thu, 07 April 2005 11:26]
kewp
wollongong
Re: turbo oil and water lines Thu, 07 April 2005 11:46 Go to previous messageGo to next message
say i could get a WRX turbo with the oil and water lines still on it, how hard would it be to hook them up
-==L=a=N=c=E==-
Brisbane, Queensland
Re: turbo oil and water lines Thu, 07 April 2005 11:55 Go to previous messageGo to next message
oil feed, popular place is from the oil pressure sensor location.
oil return, tap return into sump
water feed, any water hose you can get ya hands on
water return, tap it back into the radiator
All very fun.... *sarcasm*
feral4mr2
Bundaberg, Qld.
Re: turbo oil and water lines Thu, 07 April 2005 13:08 Go to previous message
i got my oil feed lines made from Enzed, only cost me $125 (i did get trade price though Wink ) for 2 lengths (50cm each) of braided teflon lines with fittings. steel fitting into the oil sender boss on the block and then the braided line to a T peice that holds the oil pressure sender and the other braided line to the turbo.
while your there grab some brass barbed T peices and T into your heater lines for the turbo coolant lines.
think about it and research first and a turbo conversion is a simple thing to do really. Smile
Previous Topic:dont laugh 4age into aus sprinter?
Next Topic:Brake master cyclinder for GX81 Chaser
Current Time: Sat Oct 24 04:00:55 UTC 2026
Total time taken to generate the page: 0.019470930099487 seconds
