Toymods » Tech & Conversions » 4AC shaking its booty.. help me plss...
WANTED_AE86
4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:05 Go to next message
i have a schtocker of as AE86, with 4ac in it.. when i start the ignition it shakes like hell, it wobbles and cant keep an idle properly, it idles very shaky when i feed the gas for a bit longer.. else it just stalls.. theres no power what so ever when i drove it... and i used to hear some mild clicking sound..
could this be a symptom of a blown head gasket? or just needs a new cam belt and new sparkplugs?
cheers you guys,
-dave
studman
On Probation
Charnwood
March 2005
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:15 Go to previous messageGo to next message
sounz like itz got a mad hi lift long durashon cam in it man. prolly just duzn like to idle and needz to rev to 12 grand before itz happy. jus give it more stick man. da chick will dig it
Merudo
Central Coast, NSW
February 2005
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:17 Go to previous messageGo to next message
Post retracted.
I'm sure you'll find some help here mate. Plenty of people here know their stuff! Smile
[Updated on: Fri, 08 April 2005 06:32]
shinybluesteel
melbourne
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:29 Go to previous messageGo to next message
what are you morons on about? this is the tech section isnt it? i didn't spot any takumi speak in his post.
dave, check your ignition timing, plugs, plug leads, oil, water check all the usual stuff, i'd suggest just taking it to a mechanic and getting them to take a look at it.
Merudo
Central Coast, NSW
February 2005
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:31 Go to previous messageGo to next message
shinybluesteel wrote on Fri, 08 April 2005 16:29
Sorry. I wasn't paying out the original poster. Moreso just continuing what the second guy said.
I'll delete my other post. Apologies!
NickAE86
Brisvegas
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:32 Go to previous messageGo to next message
yeah what shiny said
what sort of condition are the engine mounts in? could explain the horrible shaking
lack of power could be bhg, plugs, timing etc
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:34 Go to previous messageGo to next message
would a blown head gasket cause this kind of behaviour as well?
*And yea.. Teh Hachi Haz Ballz lyk da owner... Very Happy
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 06:43 Go to previous messageGo to next message
just checked the engine mounts ands its actually in tip top condition, when it shakes its like the whole car shakes along with the engine...
DFECTD
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 11:14 Go to previous messageGo to next message
sounds like ur running on 3cyl. Ur car is probally struggling to put the revs up. Also coul dbe startor Motor. Get it checked out by mechanic mate.
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Fri, 08 April 2005 13:25 Go to previous messageGo to next message
yeah pretty much what mi guessing, one dead cylinder not firing up... any tips for me on how to investigate it? since im keen to learn a bit of mechanics... what would it involve with.. im open for suggestion..
and oh also... heheh i have a small port waiting behind the garage.. would it be worth to hang on the 4ac till it fully dies out or slap on the SP 100kw 4age? so what u think guys? full conversion or small fixation?
cheers you'all
-dave
SPRINTAH!
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 03:04 Go to previous messageGo to next message
to find out which cylinder is dead, just pull each plug lead off one at a time, the one that makes no difference when you pull it off is your dead cylinder.
It could be a blown head gasket, my 4AG had similar symptoms when it blew out the bit between 2 and 3 cylinders, check your compression.
improvedae86
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 03:26 Go to previous messageGo to next message
Would this be the white car which also has a stalling problem on bell street next to matt black cars by chance ?
fatboy
January 2005
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 03:38 Go to previous messageGo to next message
definitely needs a tune up. everythings probably rooted. for a 4ac to run like a ratbag it has been neglected buddy. for a quick check, lift up the dizzy and check you contacts that would be first port of call. then remove leads one by one like sprintah said if that doesnt help then the last simple thing to check is your throttle cable and have a geezer at the carby. get a mechanic to check timing at this point.
to be honest if it is a head gasket the heads probably cracked behind the exhaust valves or between cylinders or something similarly ghey and financially getting a 4ac from a wrecker is you best bet. haha get a diff while your there you might get the only one left in the country that doesnt whine Very Happy
sonwill
Lara, Vic
February 2005
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 04:45 Go to previous messageGo to next message
Check you choke breaker on the carby. I had the same prob, the whole car shook, like it was unbalanced. If I held on the revs for a bit, it warmed up and was fine. It was running to rich when It was cold. I also got balck smoke out the exhaust. Fixed the choke breaker and it solved the problem'
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 12:03 Go to previous messageGo to next message
so what u think about a conversion?
shinybluesteel
melbourne
Re: 4AC shaking its booty.. help me plss... Sat, 09 April 2005 13:10 Go to previous messageGo to next message
that would probably fix the problem, or at least bring up a host of completely new different problems.
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Thu, 14 April 2005 12:54 Go to previous messageGo to next message
true.... heheh lets 4age conversion with me!!! so far i got a 100kw engine complete (loom ecu clutch flywheel etc) but what i needed ato get done is my intake to be converted to suit rwd and an exhaust manifold or extractor.... any more tips u guys can pass me? or have an exhaust manifold or extractor? it would be nice... cheers y'all!! Smile
WANTED_AE86
Re: 4AC shaking its booty.. help me plss... Fri, 15 April 2005 12:20 Go to previous message
improvedae86 wrote on Sat, 09 April 2005 13:26
yeah that was me... that white car was also a bit of a lemon and finally got rid of it (ei: constant idling problems and running rich)... this my other brown one is awaiting for a conversion....
lolz i never thought supra celica rims looks good ion sprinters man!!! where u based from?
Previous Topic:need help plz 20Valve
Next Topic:Clutch advice
Current Time: Sat Oct 24 05:43:53 UTC 2026
Total time taken to generate the page: 0.00649094581604 seconds
