Toymods » Tech & Conversions » White Smoke at idle
Roundy
Dubbo
April 2005
White Smoke at idle Sat, 09 April 2005 00:20 Go to next message
Hey guys, new member to the forum, what i have seen looks very good so far.
I have an ST185 that has an occasional white smoke at idle. The smoke smells like burnt oil Confused A while ago i had the intercooler off and it was filthy with oil and shit through it.
What could be causing the smoke at idle, it isn't a constant thing, but still oil smoke is never good!
Regards Nathan
Meat_rack
East Maitland NSW
Re: White Smoke at idle Sat, 09 April 2005 00:57 Go to previous messageGo to next message
Id take the obvious answer and say worn rings.
79rollaboy
NSW Engadine
Re: White Smoke at idle Sat, 09 April 2005 00:58 Go to previous messageGo to next message
Id take the second most obvious answer by saying valve shims... Is it more prononced when its cold starting???
Roundy
Dubbo
April 2005
Re: White Smoke at idle Sat, 09 April 2005 02:45 Go to previous messageGo to next message
no it has only happened when it was hot, and only at idle. It is not a constant thing yet, and i hope is doesn't become a constant thing, i would like to fix it before it gets any worse
toyrota
Re: White Smoke at idle Sat, 09 April 2005 08:26 Go to previous messageGo to next message
turbo seals??????
Merudo
Central Coast, NSW
February 2005
Re: White Smoke at idle Sat, 09 April 2005 08:55 Go to previous messageGo to next message
toyrota wrote on Sat, 09 April 2005 18:26
turbo seals??????
this was happening to a friend's S13 and that's what he thought it was.
sonwill
Lara, Vic
February 2005
Re: White Smoke at idle Sat, 09 April 2005 09:20 Go to previous messageGo to next message
oil in the intercooler. I would be looking at turbo seals Turbo seals also.
Toobs
Re: White Smoke at idle Sat, 09 April 2005 09:41 Go to previous messageGo to next message
turbo seals??????
Agreed!
feral4mr2
Bundaberg, Qld.
Re: White Smoke at idle Sat, 09 April 2005 10:16 Go to previous messageGo to next message
valve shims dont leak oil dude, however valve stem seals do.. Wink
white smoke normaly indicates coolant/water, but smelling of burnt oil you could of seen a light grey/blue smoke?
i've had my turbo burn oil at idle. at idle there is no positive pressure in the turbo housings that would help keep the oil from coming through worn seals, so i would agree with toyrota and the other guy's.
Roundy
Dubbo
April 2005
Re: White Smoke at idle Sat, 09 April 2005 11:25 Go to previous messageGo to next message
hmmms...i had a hunch it coulda been turbo seals...what is a way to find out for sure? or rather is there a easyish way without stripping the whole car down lol
Toobs
Re: White Smoke at idle Sat, 09 April 2005 13:06 Go to previous message
If its the turbo seals it will happen when you leave the car sitting at idle for long periods.
If it was valve stem seals it would happen the instant you turn the key and would go away as the car warmed up (unless they are really badly rooted)
Previous Topic:3T-GTE no injector pulse!!help!!!
Next Topic:2T/3T Hybrid. How to Identify one?
Current Time: Thu Nov 19 09:19:12 UTC 2026
Total time taken to generate the page: 0.0059840679168701 seconds
