Toymods » Tech & Conversions » 18R-C problems - any ideas
Lachie
18R-C problems - any ideas Sat, 09 April 2005 05:08 Go to next message
I've been having some problem with this engine for about the past 18 months or so but in the last month they got even worse and no one I know can figure out why.
It all began with the odd carby backfire when the car was cold.
To try and stop this I've rebuilt the dizzy, put on a new dizzy cap and spark plug leads. This didn't fix it.
I found a leak in the vacuum booster, so I fixed that, but it still didn't fix the problem.
Then I thought the carby might have been making it run lean, so I rebuilt that and cleaned all the jets etc, but it diddn't fix it!
I've checked everywhere else for vacuum leaks using some aerostart, but I can't find any.
The carby backfire has got more regular lately, and now when I switch the car off it runs on for about 1 or 2 seconds, then stops and about 1 or 2 seconds after it backfires out the exhaust, especially if you turn it off as soon as you stop.
The timmings all correct for the engine and I check it everytime I service it. I had other people check it, so it's not that I'm setting it wrong.
Also, lately, it been making a heap less power, and it's turning into a shit to drive.
Any ideas that anyone has would be heaps heplful. I'm gonna do a compression check on it once I can get my mates guage.
If anyone wants to see a vid of the carby backfire give us your e-mail and I'll what I can do. It's pretty cool, cause if you take the air cleaner off it shoots flames about a foot in the air!
I forgot - it's running a weber DGV off another 2L and its had all the jets changed by a professional carby place to match the 18R
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: 18R-C problems - any ideas Sat, 09 April 2005 06:22 Go to previous messageGo to next message
Don't know what the problem is but if i did i could stop mine from backfiring every now and again. sounds like a gunshot scares the shit out of me Shocked . have had it sugested to me it might be caused by an exhaust leak (ive got a bad one have you got a exhaust leak?) causing it. Smile
river
Land of Oz
Re: 18R-C problems - any ideas Sat, 09 April 2005 06:53 Go to previous messageGo to next message
Have you checked your plugs? What state are they in?
If the cylinders have carbon deposits in them, they can cause the engine to run on a bit after you've turned it off. This is because the carbon deposits are glowing from the engine being used and they are hot enough to ignite the mixture (without the sparkplug) when you turn off the motor.
If you start the engine and let if run for only a very short time (ie not up to temp) and turn it off, does it still run on? Or does it run-on only after it's been running for a while and the engine is hot? Usually, if you have some carbon deposits they run-on after the engine is hot. The best and cheapest way to get rid of the carbon deposits is to give the car a good run and let the engine rev pretty high to "burn and blow" the carbon out of the cylinder.
I'm not sure about the 18R-C, but the 18R-G has a air-bypass (or something like that) solenoid that does something when you turn off the engine. It allows extra air into the carbs or something like that to stop the engine running on. I'm sorry I can't be more specific than this. It once broke on my car and the engine would run on a bit until the solenoid was replaced. I should really do some investigation to find out exactly what it does and how. In any event, if the 18R-C has something like this, then maybe it needs to be checked also.
Also, I'd check your compression in case you've got a sticking inlet valve. The only way something is gonna blow out of your carby is if the inlet valve is open when there's an ignition occuring in the cylinder.
seeyuzz
river
earlyrolla
Re: 18R-C problems - any ideas Sat, 09 April 2005 13:59 Go to previous messageGo to next message
The solenoid you refer to is the anti-dieseling solenoid. As far as I understand it, it cuts off fuel to the idle circuit on engine power down so the engine should shut down straight away after key-off.
Depending on the Weber, it may or may not have this solenoid. The 2L Escort and Cortina ones didn't have it but the Webers that were fitted to the Falcons did.
Possibly carbon deposits.
Another theory, when was the last time the timing chain and guides were replaced?
18R's are notorious for wearing out timing guides and chains. I reckon it is a safe bet that this could be part of your problem. Under load you wont notice it as the slack on the timing chain is taken up. At idle you will notice it as the oil pressure is low and the cam will tend to move back and forth around the correct timing. This would also explain the lack of power.
Hope this is somewhat helpful.
[Updated on: Sat, 09 April 2005 14:01]
Maurice c
Re: 18R-C problems - any ideas Sun, 10 April 2005 01:46 Go to previous messageGo to next message
Check your cooling system for overheating, this might cause the engine to continue ideling but not the backfire on startup.
Lachie
Re: 18R-C problems - any ideas Sun, 10 April 2005 23:15 Go to previous messageGo to next message
Early rolla - sounds the like the problem is the timing chain, cause your spot on with it having shitty oil pressure at idle, and you can actually hear the timming change now I think about it Crying or Very Sad
I had a feeling this might have been the problem but my dad keep saying it wouldn't be that bad.
Guess I'll have to pull out the reciepts and find out when they last got changed.
Thanks for all your help guys! Hopefully I'll get it fixed now and I won't keep getting shitted all over at the lights by 202 commonwhores Smile
Maurice C : Cooling system is fine, never had a problem with it, unless I get stuck in traffic for more then 5 minutes on a 40 degree day
81lowlux : yeah, got an exhaust leak, but thats just cause when it backfired one day it blew some of the exhaust putty out the flanged between the manifold and the front pipe Laughing
And if anyones interested the weber came off a corsair, or soemthing like that I think. It's a manual choke anyway, so they never came out on any Aussie car
[Updated on: Sun, 10 April 2005 23:22]
Maurice c
Re: 18R-C problems - any ideas Mon, 11 April 2005 03:29 Go to previous messageGo to next message
How does a worn timing chain cause low oil pressure at idle? I reckon that the timing chain needs attention in my 18r-c because it seems to rattle under load( Around 2000-2500 in a high gear or uphill) and oil pressure seems to flucuate a bit as well as been low at idle. I know that the middle gear drives the oil pump and dizzy, but this would have to turn at the same speed even if the chain was worn. Thanks guys.
earlyrolla
Re: 18R-C problems - any ideas Mon, 11 April 2005 11:04 Go to previous messageGo to next message
Worn bearings are one of the causes of low oil pressure.
The timing chain uses a hydraulic tensioner, I.e. the tension is controlled by the oil pressure (to be technical there is also a little spring in the tensioner).
Worn tensioner, guides and/or stretched timing chain is accentuated by low oil pressure at idle.
As the distributor is driven off the lay shaft and it is driven through the lower timing chain, the ignition timing will change as the slack is taken up in the lower chain.
On top of this the cam is driven via the lower and the upper timing chain resulting in a worse effect on cam timing.
A friend had a problem with a common-whore not so long ago. Turned out to be a worn distributor drive gear (stupid Holden used a plastic drive gear on the distributors). Just by fixing the gear, the car was completely different to drive. The actual change in ignition timing due to the worn gear wouldnt be much but it was enough to make the car a pig at idle and very gutless off the line.
[Updated on: Mon, 11 April 2005 11:05]
Maurice c
Re: 18R-C problems - any ideas Mon, 11 April 2005 23:59 Go to previous messageGo to next message
Pretty good reply. The only problem with changing the timing chain adn gears is that they cost about 300 bucks I think which is about six times the price that am 18r-c is worth in good condition. decisions decisions.
Lachie
Re: 18R-C problems - any ideas Tue, 12 April 2005 03:10 Go to previous messageGo to next message
Maurice c wrote on Tue, 12 April 2005 09:29
Not true, priced some this morning. There about $300 form toyota (thats what the reciept from '92, when mine where last done, added up to).
At sprints a kit with all tensioners, chains, and guides was $115 for an 18R and $100 for an 18R-GEU.
I don't see the point of going guenuine on suhc an old engine that only needs to last me another year or two before I upgrade.
barned01
Re: 18R-C problems - any ideas Tue, 12 April 2005 04:10 Go to previous messageGo to next message
lachie what came in the kit for the 18rg?
chains wouldn't be that much but do they have generic guides for the g as well? as chains and dampners?
Lachie
Re: 18R-C problems - any ideas Tue, 12 April 2005 04:51 Go to previous messageGo to next message
It wasn't actually a kit for the 18R-G, but for the $100 bucks you got all the chains, tensioners and guides. Sprint at golden grove sai they could get them within a day
Maurice c
Re: 18R-C problems - any ideas Sat, 16 April 2005 06:17 Go to previous messageGo to next message
Price the same stuff in Repco and prepare to s##t yourself.
barned01
Re: 18R-C problems - any ideas Sat, 16 April 2005 07:22 Go to previous messageGo to next message
i am in the process of getting a quote from sprint, will repco frighten me or attract me to them in an unnatural way...i am guessing i will be frightened as i still find sprint cheaper that autopro/repco/superuseless
Maurice c
Re: 18R-C problems - any ideas Wed, 20 April 2005 00:38 Go to previous message
I've never heard of Sprints. I'm in teh ACT and in Repco that quoted me 180 for two chains and two tensioners. Without gears. If you can get a whole set for 115 your doing pretty well. Buy two.
Previous Topic:4age w/Greddy E-manage
Next Topic:ST185 Springs
Current Time: Mon Oct 19 17:49:40 UTC 2026
Total time taken to generate the page: 0.078366041183472 seconds
