Toymods » General Car Talk » A/D button
Todd
A/D button Sat, 09 April 2005 06:48 Go to next message
hey,
in my gz20 there is a button on the dashboard that says A/D, wat does it do??
Jag7799
Re: A/D button Sat, 09 April 2005 07:12 Go to previous messageGo to next message
Todd wrote on Sat, 09 April 2005 16:48
hey,
probably auto drive
... cruise control
Re: A/D button Sat, 09 April 2005 07:24 Go to previous messageGo to next message
Cruise Control main switch, then use the stalk to control it.
Toobs
Re: A/D button Sat, 09 April 2005 10:49 Go to previous messageGo to next message
Definately is Auto Drive (i.e. cruise control)
Witzl and I were puzzled by that one at first... but not as much as the red button above the gear shifter which has japanese characters on it.
The red button is a release button for the shifter so you can move the shifter when it would normally be locked in place.
Merudo
Central Coast, NSW
February 2005
Re: A/D button Sat, 09 April 2005 11:36 Go to previous messageGo to next message
hey,
press it so it goes green, then move the stalk (the one covered in japanese writing on the right side of the steering column) DOWN to initiate cruise control at whatever speed you're travelling.
to go UP in speed, move the stalk up. and hold it there. you will feel the car pick up speed. When you reach the desired speed, let go of the stalk and it will hold that speed. If you hear the car decelerate, that's ok. once it drops 1-2km/h below the cruise speed it will pick up and match it again. Smile
to turn cruise control DOWN in speed, hold the stalk down. let it go when the speedo reaches the desired cruise speed.
to turn cruise control off, tap the brake, pull the stalk out toward you, or press the A/D button to turn autodrive off.
Hope I have helped!
James
Todd
Re: A/D button Sun, 10 April 2005 06:30 Go to previous messageGo to next message
my cars a 5 speed manual. does this mean its been converted?
Re: A/D button Sun, 10 April 2005 08:48 Go to previous messageGo to next message
Todd wrote on Sun, 10 April 2005 14:30
If its a factory manual (look at the firewall ID plate for the gearbox code), then the cruise will work.
If the car has been converted, the cruise most likely will not work.
Re: A/D button Sun, 10 April 2005 08:49 Go to previous messageGo to next message
Toobs wrote on Sat, 09 April 2005 18:49
Its a typical japanese auto feature.
I think the yanks got it too.
Todd
Re: A/D button Sun, 10 April 2005 13:07 Go to previous messageGo to next message
when i bought it the guy said its a factory 5 speed
Arch
Re: A/D button Sun, 10 April 2005 13:14 Go to previous messageGo to next message
'the guy' will say many things in order to make sale appear more attractive.
Re: A/D button Mon, 11 April 2005 05:13 Go to previous messageGo to next message
Just check that build plate, if that says W58 then it's a factory manual. Any of the cruise controls will have a main switch.
79rollaboy
NSW Engadine
Re: A/D button Tue, 12 April 2005 05:41 Go to previous message
It helps you lay down sick dori's in front of your house...
[Updated on: Tue, 12 April 2005 05:41]
Previous Topic:50 series tyres for 14" wheels
Next Topic:My Engine Pics
Current Time: Fri Oct 23 15:15:24 UTC 2026
Total time taken to generate the page: 0.0056698322296143 seconds
