Toymods » General Car Talk » Could someone explain the term "dwell angle"
FKN16V
NSW, East Coast
Could someone explain the term "dwell angle" Sat, 09 April 2005 09:56 Go to next message
Could someone explain the term "dwell angle" and does it apply to a JDM 4age bigport?
I have aquired a tacho/dwell meter and i got no idea what the hell it means.
Steve
something
newcastle
Re: Could someone explain the term "dwell angle" Sat, 09 April 2005 10:03 Go to previous messageGo to next message
Dwell angle has to do with a points ignition system
and im guessing that motor has electronic ignition so you really don't need to worry
But if you really care its the amount of time the points are open on the cam lobe in the dizzy
or is it closed well its either open or closed
Re: Could someone explain the term "dwell angle" Sat, 09 April 2005 10:32 Go to previous message
actually - dwell angle is important in all types of ignition points style right thru to multi-coil EFI-driven ignitions.
it's to do with the amount of time 'charging' the coil (actually, it would be more accurate to say that coil windings are saturated for X duration of cam or crank rotation).
If the dwell angle is too short, the coil won't give you a deent spark - particularly at high RPM, if the angle is too long then you risk cooking your coil.
in a points system, you can modify the angle by changing the length of the wiper that rubs on the cam/lobes of the shaft - in an modern ignition system (electronic or ECU controled) you plug in numbers via a laptop or hand-held unit - if the system allows - most factory setups don't allow you to.
Previous Topic:ae82 intake tubing from any other models?
Next Topic:AE86 What colour would you respray ?
Current Time: Sun Nov 22 04:01:03 UTC 2026
Total time taken to generate the page: 0.0061650276184082 seconds
