Toymods » Tech & Conversions » Need ideas - Airbox for 45mm weber siddraft ( boxing in )
Classique71
Colac, Victoria
Need ideas - Airbox for 45mm weber siddraft ( boxing in ) Wed, 13 November 2002 09:55 Go to next message
Heys guys and gals
has anyone out there got any pictures or suggesting on how to box in a 45mm weber , so ic an then run a cold air indictuion sustem to it directly from a front mounted filterbox ( aka vn commadore for example )
ive got an idea of just simply using sheet aluminuim to make a box to bolt to the carby - and having a 3 inch inlet one end to run a flexi or fixed pipe to an airbox located in the front drivers side well in my ta22
pics of any of your mods would be appreciated fellas !!
Stuart
IRA11Y
Club Member
Re: Need ideas - Airbox for 45mm weber siddraft ( boxing in ) Wed, 13 November 2002 21:28 Go to previous messageGo to next message
Ive got a cold intake box witch should work for you that I got with my sidedrafts, made from alloy and is stepped towards the back to keep pressures pretty regular with a 60 or 50mm inlet for a pod filter, Ill take a pic later and post it up.
Classique71
Colac, Victoria
Re: Need ideas - Airbox for 45mm weber siddraft ( boxing in ) Thu, 14 November 2002 08:12 Go to previous message
thanks Smile
i only run one sidedraft - but id still be keen to have a look
Stuart
Previous Topic:Throttle cable part No???
Next Topic:A/C Cooling Unit for a Carina ST180
Current Time: Wed Oct 21 18:51:51 UTC 2026
Total time taken to generate the page: 0.004673957824707 seconds
