Toymods » Tech & Conversions » K-50 Gearboxes
Trent-KE30
Tamworth NSW
icon4.gif  K-50 Gearboxes Sat, 09 April 2005 12:21 Go to next message
hey guys,
i have read and done some research on K-50's,
now i was just wondering what cars these came in, im guessing the 5Spd KE55's and 5spd KE70's?
Are the KE70 ones identical to the KE55 ones or does it have a different bellhousing and crossmember?
Any help will be much appreciated
Cheers Trent
PS i read stewarts old corolla faq (great source of info)
Re: K-50 Gearboxes Sun, 10 April 2005 12:21 Go to previous messageGo to next message
yup, KE55 and KE70.
they have almost same front housing (inc bellhousing).
have different extension housing, different shifter position, and different reverse light switch positions. also different method of rear mount between them (but same as the 4 speed versions from those cars). you can just swap the extension housings over tho. no need to change shift rods as with the 4 speed versions.
Trent-KE30
Tamworth NSW
icon4.gif  Re: K-50 Gearboxes Wed, 02 November 2005 10:41 Go to previous messageGo to next message
Righto i got one of Clint on these forums and now i was pondering, its a KE55 one, and i want to put it onto my 3k is the 55 4k bellhousing different to the 3k or is it a bolt up?
Re: K-50 Gearboxes Wed, 02 November 2005 22:13 Go to previous messageGo to next message
K thru 5K (at least) have same bellhousing.
main differences ae the very very early smaller clutch (with smaller input shaft).... but not usually an issue.
hurricane
geelong
August 2005
Re: K-50 Gearboxes Thu, 03 November 2005 00:16 Go to previous messageGo to next message
are the K50's longer than the K40 Confused cos in my KE20 the back of the tunnel had to be cut to fit it in Sad But the car was origanaly an AUTO, ARE the AUTO and MANUAL tunnels different Wink
[Updated on: Thu, 03 November 2005 00:18]
Re: K-50 Gearboxes Thu, 03 November 2005 06:08 Go to previous messageGo to next message
hurricane wrote on Thu, 03 November 2005 11:16
K40 K50 and T50 are exactly the same length.
K50 from KE55 has same shifter position as KE20 manual.
K50 from KE70 has rearmost shifter position.
i took photos of KE10 auto and manual tunnels and they are slightly different, but not enough to worry about.
Trent-KE30
Tamworth NSW
Re: K-50 Gearboxes Mon, 07 November 2005 08:44 Go to previous message
Aight cheers once again stu Surprised
Previous Topic:sprung plate lsd?
Next Topic:ta/ra 22/23 conversions
Current Time: Wed Oct 21 13:55:32 UTC 2026
Total time taken to generate the page: 0.0046150684356689 seconds
