Toymods » Tech & Conversions » AFM maximum measuring capacity calc (flap-type)
RWDboy
AFM maximum measuring capacity calc (flap-type) Sat, 09 April 2005 12:55 Go to next message
Hey - I know I should know these things seeing as I studied fluid mechanics in University (although I never bothered to actually complete the course) but I was wondering how you can calculate the maximum flow that an AFM can measure - ie given that the spring must have force 'x' applied to it to fully compress/bind how much air would be required to generate that force?
shinybluesteel
melbourne
Re: AFM maximum measuring capacity calc (flap-type) Sat, 09 April 2005 13:07 Go to previous messageGo to next message
I also studied fluid mechanics, but i did finish my course, but the only advice i can offer you is this.
flap airflow meters are shit, avoid them at all costs.
use hotwire or MAP sensorn for airflow, if its in a stock car, just dont even worry about it.
RWDboy
Re: AFM maximum measuring capacity calc (flap-type) Sat, 09 April 2005 13:18 Go to previous messageGo to next message
Flap type air flow meters have their pros and cons, transient response is always a question mark with flap-type airflow meters and also it is clear that they are a restriction on the intake - also their shape isn't favourable (a square shaped passage will have more surface area per unit volume than a circle - not good).
Oh and also at higher flow rates the accuracy can be questionable (as the surface area decreases).
Any other help though - I really need to work this one out!
berad
Re: AFM maximum measuring capacity calc (flap-type) Sat, 09 April 2005 13:54 Go to previous message
im guessin you have a standard ecu but most afterarket ecu;s are able to calculate how much you are maxing out ur afm if it still uses it someone with powerfc or something should be able to find out something for u i know that it uses the afm unless u get the expensive model, a m8 of mine has a standard ecu was able to work out what his afm was doing when he put it on a dyno maybe ask a dyno tuning place?
Previous Topic:Bought a RWD 4a-g, going into an AE86, some questions...
Next Topic:3T-GTE no injector pulse!!help!!!
Current Time: Thu Nov 19 09:44:23 UTC 2026
Total time taken to generate the page: 0.0047669410705566 seconds
