Toymods » Tech & Conversions » Electonic ignition for 18RG
Petes76celica
Electonic ignition for 18RG Sat, 09 April 2005 13:44 Go to next message
hey guys i put electronic ignition in my RA-23 tonight but i think i may have wired it up incorrectly in starts and goes but the problem i have is when i turn the key to start it i have to keep it turned i little so to keep it running cause if i let it go the car dies i have had this problem before it ended up being the fuse and thats fine if i could get some suggestions what to check it would be good.
Pete
people100
Rocklea qld
Re: Electonic ignition for 18RG Sat, 09 April 2005 21:17 Go to previous messageGo to next message
i had the same problem in a ra23 straight after we put a 18rg in it. turned out to be dodgy ignition connections but some wd40 soon fixed it.
TA-022
Glenmore Park, NSW
Re: Electonic ignition for 18RG Sun, 10 April 2005 04:09 Go to previous messageGo to next message
had this problem two days ago.
turned out whilst i was changing an engine mount i knocked
the wire of the coil resistor / balast.
started but when you let the key return to on it died.
double check all your connections as a troubleshoot.
brett_celicacoupe
townsville NQLD
Re: Electonic ignition for 18RG Sun, 10 April 2005 06:46 Go to previous messageGo to next message
yes i too have had the same problem once
left the ignition "+" wire off the resistor, would fire/run when key was in start position but as soon as you let it off, it would die
brett
Petes76celica
Re: Electonic ignition for 18RG Sun, 10 April 2005 08:02 Go to previous message
weird thing happened with it this arfo went to play with it agian cleaned a cpl connectionsand not thinking it would change anyhing it fired weird hey so im not to sure what the problem was im guessing a dirty connection.
Pete
Previous Topic:What power can i expect from my 1JZ
Next Topic:DIY w2a intercooler core design
Current Time: Thu Nov 19 21:02:04 UTC 2026
Total time taken to generate the page: 0.014267921447754 seconds
