Toymods » Tech & Conversions » Hilux brake upgrade
SL666
Hilux brake upgrade Sun, 10 April 2005 21:54 Go to next message
Ive got a extra cab 84 YN57R hilux, i'm putting a 1J in it, i need to upgrade my brakes, anyone know of some good upgrades?
i have a set of soarer brakes from the cut.. dont know if i can use them..
sideshow
Re: Hilux brake upgrade Sun, 10 April 2005 22:49 Go to previous messageGo to next message
im fitting nissan 4 spots to my 92 hilux
the calipers will bolt straight on
just need to machine hub down and fit disc over it
then just fit spacers to get the caliper offset correct
SL666
Re: Hilux brake upgrade Mon, 11 April 2005 00:57 Go to previous messageGo to next message
so you are using skyline disks? or 300zx?
sideshow
Re: Hilux brake upgrade Mon, 11 April 2005 05:39 Go to previous messageGo to next message
i have 300zx calipers
300zx calipers are same as r32 gtst calipers
so ill be tryin to adapt the 300zx or skyline discs
the hilux discs have a thred in them and the hubs bolt to the discs
very shit design when wanting to upgrade
so unbolt the disc and throw it out
SL666
Re: Hilux brake upgrade Mon, 11 April 2005 06:54 Go to previous messageGo to next message
AFAIK the 300zx and skyline calipers aren't the same.. they are both sumitamo calipers.. the same as wrx 200sx etc etc etc but they are set wider... as 300z's have a thicker disk..
sideshow
Re: Hilux brake upgrade Mon, 11 April 2005 08:48 Go to previous messageGo to next message
theres afew diff skyline calipers so it all depends on how much money u want to spend
i think r32 gtst and 300 zx are same
r32 gtr might be bigger but since they are gtr they cost more
r33 onwards are like r32 gtr
ring sss automotive if yr after a set
but the bolt spacing for all are the same
and they fit hilux bolt spacing
200sx s15 are diff caliper
i think they are cast iron
but the easiest and cheaper ones are the r32 gtst or 300 zx
but dont expect to spend less than 400 to set it all up
unless u get parts for free or labour for free
slylux
perth WA
    nup
Re: Hilux brake upgrade Mon, 11 April 2005 10:44 Go to previous messageGo to next message
where did u get the idea for the brakes .. sideshow ??
sideshow
Re: Hilux brake upgrade Mon, 11 April 2005 11:47 Go to previous messageGo to next message
i got given 300zx calipers for helpin someone
then i removed my calipers and the nissan ones bolted straight on
its not too much work compared to makin all new brackets
i used to make brakes for alot of datsuns and the hilux seems easy compared to them
SL666
Re: Hilux brake upgrade Mon, 11 April 2005 12:12 Go to previous messageGo to next message
I'd be insanely stoked if i thought it was only going to cost me $400 to set it all up..
sideshow
Re: Hilux brake upgrade Mon, 11 April 2005 12:19 Go to previous messageGo to next message
well brakes and calipers are about 400
then u might want to put new seals or a kit in them
then u have machining of hub
SL666
Re: Hilux brake upgrade Mon, 11 April 2005 21:07 Go to previous messageGo to next message
Was having a discussion with a mate last night who has a 1G in a courier.. because my car is a commercial vehicle, i might not have to do a brake upgrade... he didn't... going to talk to the engineer i think...
but i would still like an upgrade..
fade-e
Re: Hilux brake upgrade Mon, 11 April 2005 21:13 Go to previous messageGo to next message
the skyline and 300ZX Z31 are the same at 26mm thick and the Z32 is 30mm thick rotors
sideshow
Re: Hilux brake upgrade Tue, 12 April 2005 07:13 Go to previous messageGo to next message
i have a 1uz in my hilux and one enginner didnt want brakes upgraded
the other did so i went with the first guy
but in the long run better brakes makes it a better and safer car
do not do it cause engineer said to or not
do it for yr safety
ive been so busy i got no time to work on my car
i just managed to rewire it again 3rd time
cause i didnt like it hehe
i hope to do brakes in next month or so as i have most parts
SL666
Re: Hilux brake upgrade Wed, 13 April 2005 00:57 Go to previous messageGo to next message
okay, after rattling round in the DBA cattledog, ive noticed a couple of things...
the SR5 runs a smaller disk than the standard hilux... 248x22mm
the standard hilux runs a 257x25mm the same part number as a hiace...
a hiace also had a version available with 15" wheels.. that had a 285x28mm disk..
anyone know of one of these hiluxes they could get a look at to see? any ideas how to find out?
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: Hilux brake upgrade Wed, 13 April 2005 04:35 Go to previous messageGo to next message
i have a hilux with 4 wheel drums and the engineer said i dont need a brake upgrade even if i put in a 5ltr v8 Shocked will be doing one for piece of mind though
SL666
Re: Hilux brake upgrade Wed, 13 April 2005 04:58 Go to previous messageGo to next message
thats scary... there's a hell of a lot more weight over the wheels..
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: Hilux brake upgrade Wed, 13 April 2005 05:12 Go to previous message
i said to the guy, what brake upgrade do i need and he said for that year and model hilux and that year engine i don't need one Shocked , i said you would have to bee crazy Eye Spin not to. he agreed but never the less he would pass it.
Previous Topic:MA61 Power Steering Rebuild - Cost
Next Topic:XT130 Hilux Brake Upgrade.What pads should I use?
Current Time: Fri Oct 23 17:31:14 UTC 2026
Total time taken to generate the page: 0.0056979656219482 seconds
