Toymods » Tech & Conversions » Engine Stalling
CD1J
April 2005
Engine Stalling Sun, 10 April 2005 22:54 Go to next message
I've got a problem with my chaser when I start it if I touch the accellerator it stalls the car. I can hold the accellerator just on and it will drop the revs like its chocking the car and more accellerator any it'll stall. If I leave the car for 5 mins or so it won't stall. It seems to happen when I the auto throtle (I think thats what its called?) is on and the revs are up. Any info would be awesome
~ Cheers
hokey
Kilsyth, Melbourne
Re: Engine Stalling Mon, 11 April 2005 03:37 Go to previous messageGo to next message
yeh thats just because the choke is on. i think all you need to do is let it warm up for a bit before you start feeding alot of throttle.
-Calvin
CD1J
April 2005
Re: Engine Stalling Mon, 11 April 2005 04:19 Go to previous messageGo to next message
yeah your probably right but the thing that worries me is that it hasn't always done it, why has it started doing it? could of the start of a big problem or it could just be nothing either way I'd like to know just so I'd know - ya know Razz
wogman_83
January 2005
Re: Engine Stalling Wed, 13 April 2005 23:11 Go to previous messageGo to next message
hey sounds like your auto choke is not working cause when you first start a car its cold and it bogs down does it rev up like it used to or does it sit at 800 rpm straight away this i assume is when its dead cold like hasn't been driven for like a couple of hours Smile
CD1J
April 2005
Re: Engine Stalling Thu, 14 April 2005 00:53 Go to previous messageGo to next message
choke works, it goes to about 1500 RPM or so when its started and comes down but during that period you can't give it any revs when it comes down to 800 (idle) its usually good, but yeah this happens when its dead cold. oh and whats that guys number that you got ya supera stuff off?
Re: Engine Stalling Thu, 14 April 2005 01:07 Go to previous messageGo to next message
Fuel injected cars don't have a choke. Rolling Eyes
The behaviour definitely is not normal. It sounds like an air leak, so check carefull for any loose connections or wayward hoses in your inlet system.
CD1J
April 2005
Re: Engine Stalling Thu, 14 April 2005 01:11 Go to previous messageGo to next message
don't they have auto choke? Embarassed
wogman_83
January 2005
Re: Engine Stalling Thu, 14 April 2005 02:16 Go to previous messageGo to next message
yeah injected cars just pump more fuel in to bring the revs up and get it warm when it thinks its warm it drops the fuel rate off breese said it might be the tps throttle position sensor but yeah air leak could be it but if it goes away that probably isn't an air leak any way the warm up is controlled by the computer so i hope its something simple.
that number is 0403218108 you probably go to message bank thou
E.I.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Engine Stalling Thu, 14 April 2005 02:21 Go to previous message
wogman_83 wrote on Thu, 14 April 2005 12:16
E.I.
Fuel Injected engines bypass air from behind the throttle body into the manifold to bring up the revs, either the pressure drop (MAP) or air flow difference (AFM) is measured and extra fuel is metered in accordingly.
Previous Topic:short shit for 3sge
Next Topic:Places in syd to get my webers (2tg) dyno tuned
Current Time: Fri Nov 20 04:55:39 UTC 2026
Total time taken to generate the page: 0.0046548843383789 seconds
