Toymods » General Car Talk » engineer's certificate???
piggy
newcastle nsw
March 2005
icon5.gif  engineer's certificate??? Mon, 11 April 2005 11:28 Go to next message
hi there im new to NSW and i was wondering if i buy a car which was built with an 18rc and replaced with an 18rg do i need an engineer's certificate for it to be able to become road worthy as the car is currently in QLD?
thanks Chris
STR8 2.8
Re: engineer's certificate??? Mon, 11 April 2005 11:36 Go to previous messageGo to next message
nah
piggy
newcastle nsw
March 2005
Re: engineer's certificate??? Mon, 11 April 2005 11:38 Go to previous messageGo to next message
ok cool are you sure you don't require one? as this is my first car some im kinda new
Re: engineer's certificate??? Mon, 11 April 2005 13:23 Go to previous messageGo to next message
depends - if in qld and you had an 18R powered RA40 and upgraded to EFI 18RG (well GUE to be exact) you should have had the change in induction system blue-plated (engineered).
but if it's still a carbi engine, then it's probably fine as is unless your local inspector in NSW decided to check whether 18RG was available as an option with your model of Celica (and i'm guessing that it's a Celica in which case it's probably ok?)
country-wide rule of thumb: if it was a factory option for your car, there's no need to engineer it
piggy
newcastle nsw
March 2005
Re: engineer's certificate??? Mon, 11 April 2005 20:19 Go to previous messageGo to next message
ok thanks for your help it is a RA40 celica thanks for your help but ill still have to change the vin number as the engine number would be different??
thanks chris
Celica_John
Re: engineer's certificate??? Fri, 15 April 2005 02:31 Go to previous messageGo to next message
all you'd need is a blue slip.
I'm fairly certain.
blue slips are about 80 bux compared to an engineers certificate which is more like 500 bux
Re: engineer's certificate??? Fri, 15 April 2005 02:39 Go to previous messageGo to next message
since the 18rg and 18rgu were available in the 1977 celicas from the factory and there is no significant power increase or change in induction system then it is a "owner certified modification".
Meaning you just get a blue slip engine number change and you are done Very Happy
Allan
Re: engineer's certificate??? Fri, 15 April 2005 03:05 Go to previous messageGo to next message
get the owners hand book for an ra40 open it up and there is a photo of an 18R-GE siting in the bay from memory that should be all you need
Allan
Celica_John
Re: engineer's certificate??? Fri, 15 April 2005 12:09 Go to previous message
The person that did my blue slip said that if the engine bolts in with no modifications you don't need an engineers certificate. I told him I had a celica and he said if I put in the 18rg it would be fine to register after I got a blue slip. If you put something else in that requires engine mounts to be modified etc it needs an engineers certificate.
That was the crux of what he told me.
Previous Topic:ae86 gauge mount
Next Topic:MA70: Feedback pls
Current Time: Thu Nov 19 23:19:47 UTC 2026
Total time taken to generate the page: 0.009509801864624 seconds
