Toymods » Tech & Conversions » MA70 Intercooler Setups
HKS_TRD
MA70 Intercooler Setups Tue, 12 April 2005 03:02 Go to next message
I am looking at installing a larger front mount intercooler on my MKIII Supra which runs a 7M-GTE. I currently have a HKS unit on there(which will be for sale at some point) which is a direct replacement for the original but am looking to go larger. I want to run a core with the tanks on the sides rather than top to bottom like the current setup. The problem with this is the piping layout of the 7M requiring the pipe from the turbo to cooler to go across the intercooler to meet up to the end tank.
Alot of people have done this already BUT has anyone still managed to keep the engine undercover plastic thingy, I want to keep this. Also curious what if anything did you need to relocate to make room for the core and what size was the core?
Thanks in advance for any constructive input
Dan
HKS_TRD
Re: MA70 Intercooler Setups Wed, 13 April 2005 01:56 Go to previous messageGo to next message
^^^^^bump
Danners
Central Coast, NSW
Re: MA70 Intercooler Setups Thu, 14 April 2005 01:29 Go to previous messageGo to next message
I too would like to know about this... free bump!
Dan
Tats
Wollongong, NSW
Re: MA70 Intercooler Setups Thu, 14 April 2005 11:46 Go to previous messageGo to next message
I'm also interested in people's experience. I'd like to get a rough idea of cost and difficulty, of piping and bends.
celicaboy2000 had a massive front mount on his MA70 from what I saw, is he still around?
HKS_TRD
Re: MA70 Intercooler Setups Fri, 15 April 2005 06:34 Go to previous messageGo to next message
I think the biggest problem is if you want to keep the factory undercover, which does aid in airflow and cooling. Most setups I see have that eliminated and the core hangs low. What I am thinking is the go is having the pipe from the turbo run inside the recess of the undercover across to the passenger side of the car and then meet up with the tank of the cooler. From what I have been told, side to side air-flow is the way to go, or atleast with the turbo size I have. It seems that by modifying the brakcet that holds the bonnet catch you can make some extra room. Shouldnt need to cut into the bumper reinforcement. Would be nice to see someones setup to get an idea of what core size can be acommmodated. The pic below is of the HKS core I currently run which is a direct replacement for the stock core
http://www.turbosupras.com/images/members/intake/dts/HKS%20Jap%20Spec%20Intercooler.jpg
[Updated on: Fri, 15 April 2005 06:38]
celicaboy_2000
Lismore, NSW
Re: MA70 Intercooler Setups Fri, 15 April 2005 11:29 Go to previous messageGo to next message
I had a 600x300x76 Greddy cooler, Ill post some pics but I dont know how to in here... If anyone wants the pics and that can post them in Tech let me know... I spent just under a 1K for stainless steel with mandrel bends, the cooler had the intake and outlet on different sides. The pipe from the turbo housing ran behind and a little lower parallel to the bottom radiator tank to the lefthand side of the cooler (to make it neater had a slight hump near the bottom radiator hose). The outlet pipes of the cooler basically follows the same route as the factory pipes. I modified the bonnet lock support to let the cooler fit, also I mounted the cooler behind the reo. I did eventually cut the reo out and modified the bar to let more airflow to the cooler. Ummm does tht help at all?
[Updated on: Fri, 15 April 2005 11:33]
Danners
Central Coast, NSW
Re: MA70 Intercooler Setups Wed, 20 April 2005 00:53 Go to previous messageGo to next message
Celicaboy's Pics:-
http://members.iinet.net.au/~danners/DSC00668.JPG
http://members.iinet.net.au/~danners/DSC00666.JPG
http://members.iinet.net.au/~danners/DSC00602.JPG
http://members.iinet.net.au/~danners/DSC00674s.JPG
Stenno
Re: MA70 Intercooler Setups Wed, 20 April 2005 04:57 Go to previous messageGo to next message
Danny, do what your brother has done and stop ricing the damn car! Wink
Danners: That is a scary amount of intercooler piping Shocked
Danners
Central Coast, NSW
Re: MA70 Intercooler Setups Wed, 20 April 2005 05:41 Go to previous messageGo to next message
lol - its not my car! I wish it was Very Happy
Those pics are of celicaboy's old ride
celicaboy_2000
Lismore, NSW
Re: MA70 Intercooler Setups Wed, 20 April 2005 10:40 Go to previous message
Stenno, the piping isn't that scary. What else can you do to use a intercooler that has the inlet & outlet at different ends? I have seen alot longer intercooler tracts than what I had installed. The difference between boost lag between that setup to the standard setup wasn't that noticeable! anyhow I was happy with the result at the end Very Happy
Danners, cheers for posting up the pics.
Previous Topic:gear selector for AE111 6 speed
Next Topic:2tgue valve seals??
Current Time: Sat Oct 17 21:22:11 UTC 2026
Total time taken to generate the page: 0.0060470104217529 seconds
