Toymods » Tech & Conversions » XT130 Hilux Brake Upgrade.What pads should I use?
13BTA22
XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 04:31 Go to next message
AS the thread says.I have done a search but the Green pads need a lot of heat to work.Is their something in the middle for street and strip.
Cheers Pete
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 04:32 Go to previous messageGo to next message
Green stuff works from stone cold.
13BTA22
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 05:55 Go to previous messageGo to next message
Have you tried and tested.Just want to make sure before I get them.
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 05:56 Go to previous messageGo to next message
Yes, I have greenstuff on my car now.
Even stone cold it pulls up well.
Probably has something to do with the 280mm discs and 4 spot calipers.
Either way, it stops.
EVOSTi
cambo
      no
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 06:16 Go to previous messageGo to next message
incase you didnt already realise, you dont have to use hilux pads, you can modify early WRX or 200SX pads to fit, giving more range.
Henn
Rosanna, Melb
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 13:57 Go to previous messageGo to next message
Greenstuff are great. You do feel them bite better once you've given them a good thrashing and warmed them up, but even from dead cold they stop absolutely fine. No problems.
And Evo is on the money, there are a huge number of pads for different models which fit.
Hen
M.W.P.
Rocky Mountains, Canada
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 17:16 Go to previous messageGo to next message
EVOSTi wrote on Tue, 12 April 2005 15:46
Ive also heard similar things.
Do you know exactly how they need to be modified?
shinzui
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 21:55 Go to previous messageGo to next message
I've got bendix ultimates (for 200sx) in mine, no modification necessary.
ra23celica
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 22:30 Go to previous messageGo to next message
I have bendix heavy duty 4wd Hilux pads in my Hilux calipers and they work great, from cold, from hot, from anytime.
13BTA22
Re: XT130 Hilux Brake Upgrade.What pads should I use? Tue, 12 April 2005 23:46 Go to previous messageGo to next message
Thanks for all the info guys.Now I can go and spend more money.
Cheers Pete
dorikin
NE Melbourne
Re: XT130 Hilux Brake Upgrade.What pads should I use? Wed, 13 April 2005 02:49 Go to previous message
i'm using Mitsubishi GTO pads. they fit too, and they are deeper than the 200SX or WRX pads so they swipe more of the disc. they are Greenstuff, and yes i do agree with all the above comments. well worth the money!!!
Previous Topic:Hilux brake upgrade
Next Topic:Engine Crossmember Measurements
Current Time: Fri Oct 23 03:55:45 UTC 2026
Total time taken to generate the page: 0.0059239864349365 seconds
