Toymods » Tech & Conversions » more 2tg poke
cooter
perth
more 2tg poke Tue, 12 April 2005 05:06 Go to next message
hey guys im looking for a lil more poke from my 2tgeu. ive already got cai, extractors +2 1/4 exh and pod. im thinking cams are the next step. what grind would be suitable for a nearly stock 2tgeu?. im after good midrange and topend. also i have herd that the geu computer cant handle much modification so would it be worth putting on my set of 40mm delotos so that i can tune for the cams and then i can go back to efi later when i get more money for new ecu etc. oppinions?? also if i do go with the carbs what is a suitable dyno tuner that knows what they are doing in perth and what would i be looking at paying roughly?
cheers for any help
craig
pheonix83
Devonport Tasmania
Re: more 2tg poke Tue, 12 April 2005 06:00 Go to previous messageGo to next message
in short, more poke means more money
i would put a 3tc bottom end in it, then maybe put some 3tgte injectors on the factory puter.
i think they are the same impedence, should cover your fuel issues, its rough, but would work.
JP_TA22
Re: more 2tg poke Tue, 12 April 2005 08:46 Go to previous messageGo to next message
For the dyno tuner, try Barries Dyno, off Welshpool Rd along the railway line. Never heard a bad thing about him, and from memory he charges quite reasonably.
TA22-3SGTE
MACKAY
Re: more 2tg poke Tue, 12 April 2005 11:00 Go to previous messageGo to next message
A set of 288 degree cams , get about .040" machined off the head to get the comp up so the cams will work and put the carbies on .
Trevor
Redwarf
February 2005
Re: more 2tg poke Tue, 12 April 2005 12:46 Go to previous messageGo to next message
Webers/ Dellortos. If nothing else, it'll make the right noise. I've got 40's on mine and it goes well. Dyno is a must.
FASTFOO
melb
February 2005
Re: more 2tg poke Tue, 12 April 2005 13:20 Go to previous messageGo to next message
Get on to Andrew at central vic auto parts (TOYMODS SPONSOR) he can build a pretty mad 2TG (kicks crap out of my 4AGE sprinter) Sad
What Andrew does not know about 2TG is not worth knowing. Cool
MATT.
EldarO
Perth, WA
Re: more 2tg poke Tue, 12 April 2005 15:06 Go to previous message
FASTFOO wrote on Tue, 12 April 2005 21:20
MATT.
the guys in Perth man...
one thing i will recomend though, DO NOT FOR YOUR LIFE goto speedworks, if you own anything that isnt sub 11 sec they will spit on you.
Eldar.O.
Previous Topic:Putting baffles in AE86 tank?
Next Topic:sprinter suspension decisions
Current Time: Sun Oct 18 17:54:47 UTC 2026
Total time taken to generate the page: 0.040239095687866 seconds
