Toymods » Tech & Conversions » 2tg head on 3t block
whatignorance
February 2005
icon4.gif  2tg head on 3t block Tue, 12 April 2005 05:14 Go to next message
Before I start I have searched for this topic and there is so many posts I was just going round in circles. Everyones opinion seems to contadict each other. Can someone please confirm some things for me.
I have a complete 3t bottom end, and a complete 2tg. The 2tg is not injected.
Am I correct in saying that to make a ~2L 2TG-3T hybrid, I need to:
- Fit the 2TG head onto the 3T block, or being a carbied 2TG will the cam bearings not fit?
- Bore the 3T block out to 89mm
- Flycut the 3T pistons, or use 2TG rods, or both?
Evil_Foetus
Ballarat, Victoria
Re: 2tg head on 3t block Tue, 12 April 2005 06:24 Go to previous messageGo to next message
bore out to 88.5mm, 89 is very hit and miss- its trial and error if you get a block with enough meat to bore- you may be too close to the water jackets.
same trouble 'the untouchable' had. pm him for details. needless to say it was too much of a pain for him.
2tg head needs a dummy cam or something
you flycut the 3t pistons on the 2 rods, i think.
im sure someone can clear this up for you, im no 2tg expert Laughing
crokdee
Re: 2tg head on 3t block Tue, 12 April 2005 06:41 Go to previous messageGo to next message
I am in the same boat here...not sure which choice to go with. Have a complete 3tc and getting a 2tg. People say to use the bottom end of the 3tc, yet others say for the hybrid, use the 2tg block and just add the 3t pistons/crank - increase compression without really having to modify the head.
Best to use? because i settled on...2tg rebuilt with new carbs, new aggressive cams, port and polish, bored to 1800, 3t pistons/crank (maybe billeted - i think possible)making it 2lt (i think yes?)then lightened flywheel and heavy clutch.....keep with that idea, or use 3t bottom end?
Loan is coming though very soon, so ideas would be great.
crok.
September_Squall
Melbourne, Australia
March 2005
Re: 2tg head on 3t block Tue, 12 April 2005 13:23 Go to previous messageGo to next message
The 2T and 3T rods are the same dimensions.
The 3T crank can only be used with 3T pistons (or pistons with 3T gudgeon pin geometry).
You get about 1940CC from 89mm x 78mm. It's not that hard to calculate. Hint: Pi = 3.14159
thetoyman75
Club President
Re: 2tg head on 3t block Wed, 13 April 2005 05:16 Go to previous messageGo to next message
Short Version
Use 3T Pistons and Crank, pistons will require flycutting
2T, 3T, 2TG rods - All the same length so interchangeable (Don't mix and match tho, they are different) - Keep an eye on rod bearing oil hole locations !!!
ANY 2T, 3T series block will do. early 2T-C blocks will need clearancing for 3T crank.
The Half cam drives the oil pump and Dissy, It goes where the std cam goes in a xT-C engine. remember to block the unused cam bearing oil holes to maintain oil pressure.
88.5mm is biggest "safe" bore size. Bigger is possible tho not worth the gamble IMHO
A xT-G reguires xT-G timing gear, timing covers etc !
Cams and Headwork etc etc depends on application.
Hope that helps !
hokey
Kilsyth, Melbourne
Re: 2tg head on 3t block Wed, 13 April 2005 13:03 Go to previous messageGo to next message
wot was that about a dummy cam? wot does this mean?
Re: 2tg head on 3t block Wed, 13 April 2005 13:16 Go to previous messageGo to next message
The dummy shaft goes in the block where the camshaft would go in an OHV engine. It's there to drive the distributor and oil pump. There are two timing chains, one goes from the crank to the dummy shaft and the other goes from the dummy shaft to the actual camshafts.
hokey
Kilsyth, Melbourne
Re: 2tg head on 3t block Wed, 13 April 2005 13:21 Go to previous message
oh yes thats rite i remember now
cheers, Calvin
Previous Topic:HELP HELP!!!! Drive shaft problem!!
Next Topic:Volunteers for AFM experiment please !
Current Time: Sun Nov 1 11:07:06 UTC 2026
Total time taken to generate the page: 0.004443883895874 seconds
