Toymods » Tech & Conversions » Removing Supercharger
ke35 - 4AGZE
Removing Supercharger Tue, 12 April 2005 06:12 Go to next message
hey guys,
just wanted to know if any1 has been able to remove the sc from a 4AGZE without taking the engine out of the car??
i have taken everything off, my only problem is that i cant remove the main pivot bolt at the bottom of the sc because the engine mount is in the way.
am i just going to have to take the engine out or is there an easier way around this.
btw. 4AGZE, rwd, ke35
ae86slaver
Re: Removing Supercharger Tue, 12 April 2005 06:27 Go to previous messageGo to next message
you'd have to get an engine crane and unbolt that engine mount to remove that cradle.
I removed my supercharger without having to take that cradle off cuz my idler pulley needs it. So it worked well
we spent about 3 hours removing the SC12 - pretty easy and straighforward, just work from the top down, and be careful not to break the knock sensor/any other sensors in there
easy as
Adsport
Perth WA
Re: Removing Supercharger Fri, 22 April 2005 00:10 Go to previous messageGo to next message
just get a jack and some blocks under the motor and support it when you take the engine mount out, remember to slip the bolt in through the other way when you reinstall it.
3 hours? your mad it takes 20 mins to do in an aw11
drift86levin
brisvegas
Re: Removing Supercharger Fri, 22 April 2005 02:49 Go to previous messageGo to next message
ahhh yeh...knock sensor.. Rolling Eyes
had to get a new one when i put my worked head on...
IF by any chance you break the weak as a straw like, plastic that it is held together with, 7MGTE's have the same knock sensor, and it is more metal than plastic.. Very Happy
EVOSTi
cambo
      no
Re: Removing Supercharger Fri, 22 April 2005 06:35 Go to previous message
i got my supercharger off no problems while still in the car, didnt unbolt the engine mount or anything, used a crowbar. noting broke, all was sweet.
Previous Topic:using 16r rods to stroke a 18r
Next Topic:86' SETUP
Current Time: Sat Oct 31 16:08:33 UTC 2026
Total time taken to generate the page: 0.038721084594727 seconds
