Classifieds » Parts Wanted » Lift pump
LeZZa
Lift pump Tue, 12 April 2005 13:49 Go to next message
I'm after a lift pump for my surge tank setup to go with a VL turbo pump -> 4agze. I'm in Adelaide, but willing to pay freight.
If no one has one, where can i get a suitable pump for a reasonable price?
Thanks.
gabe
Re: Lift pump Tue, 12 April 2005 14:08 Go to previous messageGo to next message
I have a brand new Pierburg pump I am not using anymore if you are keen....
Gabe
chrisellis
Re: Lift pump Tue, 12 April 2005 14:22 Go to previous messageGo to next message
i have the same sutup as u, vlt pump + lift and surge in boot (for a gze). i use a pierburg as the lift pump, has worked great for the past 6 months, got it for $130 brand new from a local automitive performance shop. hope this helps.
mcostalos
Adelaide, South Australia
February 2005
Re: Lift pump Tue, 12 April 2005 14:43 Go to previous messageGo to next message
I have a VL Turno fuel pump for you if you are keen. $50. In adelaide as well.
Michael
chrisellis
Re: Lift pump Tue, 12 April 2005 21:53 Go to previous messageGo to next message
my understanding is that he's after a lift pump, and already has a vl turbo pump...
gabe
Re: Lift pump Tue, 12 April 2005 23:17 Go to previous messageGo to next message
Mine is yours for 80 bucks plus postage.
Like I said, brand spankers!
Gabe
Rallystanza
Re: Lift pump Tue, 12 April 2005 23:59 Go to previous messageGo to next message
Il take your one gabe!
Jezza
PM some details...
mcostalos
February 2005
Re: Lift pump Wed, 13 April 2005 01:05 Go to previous messageGo to next message
You can use a VL pump as a lift pump no worries whatsoever.
My mate is using 2 VL pumps for his 1G-GTE with the surge tank and that will work fine for him.
A VL pump will lift enough!
Michael
gabe
Re: Lift pump Wed, 13 April 2005 03:53 Go to previous messageGo to next message
mcostalos wrote on Wed, 13 April 2005 09:05
I am sure it will but you will be pressurising the surge tank to 100 odd psi. Not ideal. All associated fittings and hoses will need to be EFI items and depending on the setup, you will be pressurising your main tank too!
When running an external surge tank, either gravity feed it or use a low pressure pump to fill it.
It is the right way to do it.
Jezza I will send you a PM....
Gabe
mcostalos
February 2005
Re: Lift pump Wed, 13 April 2005 08:45 Go to previous messageGo to next message
Where did you pull 100 psi from. Honestly, it doesn't seem like you really know what you are talking about. If you want a cheap option that will work well, then i would go for a VL Punp. You don't need to go overboard. Ask around. My uncle is a drag racer, and i've passed this setup by him and he said it would work totally fine. $50 and it's yours.
Michael
gabe
Re: Lift pump Wed, 13 April 2005 11:42 Go to previous messageGo to next message
Michael,
Without getting into an argument, your setup is unsafe.
Bosch fuel pumps, which is what a VL turbo pump is, when new pump fuel at a pressure of 100Psi, I may be off on the pressure, but not by much.
If you have the surge tank on the pressure side of the pump, yes it will work, but every outlet on the tank will be at the same pressure, including the over flow line back to your main tank and any filters you have. You can do it this way if you want, but ensure you use EFI hose and clamps as regular ones will not handle the pressure.
If your uncle is an experienced drag racer as you say, get him to have a look at the setup in your car, and look at ways you could make it safer. Smile
Fuel spraying around at high pressure is dangerous....
Gabe
Rallystanza
Re: Lift pump Wed, 13 April 2005 12:29 Go to previous messageGo to next message
Il buy ya lift pump gabe,
Check pm,
Jezza
LeZZa
Re: Lift pump Thu, 14 April 2005 22:35 Go to previous messageGo to next message
Thanks for the replies everyone. Should be sorted soon.
LeZZa
Re: Lift pump Sun, 08 May 2005 12:46 Go to previous messageGo to next message
I don't suppose you still have that lift pump do you?
thanks,
Leon
gabe
Re: Lift pump Sun, 08 May 2005 12:49 Go to previous messageGo to next message
Me?
Sorry mate it's as good as sold....
Gabe
mcostalos
February 2005
Re: Lift pump Sun, 08 May 2005 15:31 Go to previous messageGo to next message
I have a normal VL pump that can be used as a lift pump. Sold the turbo one. You can have this one for only $30.
Michael
CLG
Perth, Western Australia
Re: Lift pump Mon, 09 May 2005 01:57 Go to previous messageGo to next message
I seriously wouln't be using a high pressure pump in a lift pump situation, you'll probably find the original hoses will kill themselves very quickly. Having said that, I have a couple of low pressure lift pumps ideally sized for a 4AGZE, will PM you.
Rallystanza
Re: Lift pump Mon, 09 May 2005 02:39 Go to previous messageGo to next message
gabe wrote on Sun, 08 May 2005 22:49
Me?
Gabe
Yeah gabe send it with the engine if you can...?
Cheers mate
Jezza
improvedae86
Re: Lift pump Mon, 09 May 2005 03:26 Go to previous message
Jezza , i have a left over f18 jet pump , good for 1000psi . Should be ok as a lift pump , just run two alternators and a 24volt system to get the amperage required . Ow turn the lights off at night might help that current draw Laughing
Seriously i have lost count of how many VL pumps used as the lift / supply pump i have seen shit themself's in sprinter , IDB in richmond was famous for running them drawing from a 6mm line size to the 8mm outlet , then to a 6mm filter , then to the rail , then a 4mm return lol . This kind of shitty install on a fucked pump { alway's fucked straight away due to the installation } normally worked out at a fuel rail pressure of 83psi at idle . Yeah when about 38 is properly required for your gze . Search the tech section , dodgy fuel set up's are a death wish for you and your engine . Also i wouldn't use a VL pump if you paid me , there way to overated for the price compared with the new designs on the market now .
Previous Topic:MicroTech LT8 or Wolf 3D
Next Topic:100KW Flywheel
Current Time: Wed Oct 21 03:45:25 UTC 2026
Total time taken to generate the page: 0.13909101486206 seconds
