Toymods » Tech & Conversions » What is a Compression and leak down test
Les
icon5.gif  What is a Compression and leak down test Tue, 12 April 2005 22:47 Go to next message
Hi guys, can someone explain what they the comp test and leak down test does ?
Where can I get them done around the hills area ? And around how much does it cost ?
[Updated on: Tue, 12 April 2005 22:48]
Re: What is a Compression and leak down test Tue, 12 April 2005 23:06 Go to previous messageGo to next message
Compression test is just that, tests the compression of the engine. So how well the rings/valves are sealing the combustion chamber.
Leak down test is handy if you have low compression. You can tell if its the rings or valves that is allowing the engine to loose compression.
Most mechanic workshops should be able to do it, can't imagine it being more than $50.
Les
Re: What is a Compression and leak down test Tue, 12 April 2005 23:17 Go to previous messageGo to next message
Cool thanks mate
apparently lube mobiel do it too !
how long would it generally take?
barned01
Re: What is a Compression and leak down test Wed, 13 April 2005 00:05 Go to previous messageGo to next message
for 40 bucks you could buy a compression tester. and do it yourself, if you have low compression in a cylinder after doing a test you can find out if it is the rings or valves by putting in a small amount of oil.
anyway method is
buy compression tester.
pull sparkplugs out (keep them in the same spot so you can examine if the sparkplugs are alright for the cylinders)
disconnect ignitoin so it doesn't spark unwantedly everywhere.
put compression tester in cylinder
open throttle wide open
crank engine over for about 5 or so seconds
let go of throrrtle, check reading on guage.
repeat for other cylinders, and they should all be within about 5% of each other.
if one is low then pour about a teaspoon of oil in the cylinder and re run the compression, if it significantly goes up then rings are on way out, if it is still low then valves are the issue.
go on buy one, you know you want to.
barned01
Re: What is a Compression and leak down test Wed, 13 April 2005 00:07 Go to previous messageGo to next message
and if a group of cylinders is lower than some other cylinders then it might be head gasket related
Les
Re: What is a Compression and leak down test Wed, 13 April 2005 01:20 Go to previous message
$70 down the road .. save me the hassle
Previous Topic:3sgte idle control
Next Topic:Brake Fluid - Nees topping up but......
Current Time: Fri Oct 23 04:53:25 UTC 2026
Total time taken to generate the page: 0.082286834716797 seconds
