Toymods » Tech & Conversions » brakes are not working
ripgsr94
April 2005
icon1.gif  brakes are not working Wed, 13 April 2005 01:30 Go to next message
i have a mr2 sw20 (92)
aus spec with jap spec motor. Problem with stopping up, very very slow but can still lock them up?? is this due to the fact that the car is so light? no abs Sad will a new set of rotors and calipors fix this if so which ones would be suggested as i do not have much money Very Happy
ra23celica
Re: brakes are not working Wed, 13 April 2005 03:21 Go to previous messageGo to next message
Mike,
Don't spend big dollars on new gear like rotor's and calipers until you fix the problem you have with the car now, otherwise there is a chance you will still have the same problem afterwards.
Replace all the brake fluid with fresh clean stuff and bleed the system. Look at the pads of all four corners and replace any that are worn down to the backing plate. Inspect the rotors for thickness and any cracks. Check your calipers push out the pads smoothly.
Tells us what its like to drive/stop after that.
Mitch.
M.J.H
Re: brakes are not working Wed, 13 April 2005 05:08 Go to previous messageGo to next message
What does the pedal feel like?Does it need a lot of effort to push the pedal or not?
Could be the vac line to the booster (i assume they use one)
Or the pads could have gone hard and need replacing.
Kyosho
Wollongong
Re: brakes are not working Wed, 13 April 2005 06:33 Go to previous messageGo to next message
What sort of tyres do you have on it as well?
If you have bad tyres on the car, braking can feel quite bad, and lockups very easy...
ripgsr94
April 2005
Re: brakes are not working Sun, 17 April 2005 13:25 Go to previous message
yea the rotors do need to be machined as they are a little glossed, but new pads all round... have changed brake fluid only using a dot3 i think , but i wouldnt think it would need 2 be much higher than factor(dot3) standard as they are standard brakes... will try another set of tyres though, forgot about them connecting me to the ground lol cheers guys
Previous Topic:w5x into ke10
Next Topic:Camry Performance Upgrades
Current Time: Sat Nov 21 17:14:56 UTC 2026
Total time taken to generate the page: 0.0090830326080322 seconds
