Toymods » Tech & Conversions » Engine Crossmember Measurements
wilbo666
Engine Crossmember Measurements Wed, 13 April 2005 01:30 Go to next message
I was exploring the possibility of using the crossmember out of another car in the effort to convert to rack and pinion steering (would then enable the fitment of a 1JZ-GTE with stock turbos to a MX62 cressida, currently I think the steering box will foul the turbos, tho I am not 100% sure. I haven't checked). Better steering response would also be achieved, and perhaps a reduction in the currently horrendous number of turns lock to lock.
As such I have taken measurements of a MX62 cressida engine crossmember, I was hoping that we could create a "tech depositary" of types if everyone that has access to a crossmember could take a picture and add some measurements. It would also allow people to identify unknown crossmembers in the future Smile
http://everest.fit.qut.edu.au/~n4150414/Random/MX62%20Crossmember%20Measured.JPG
Re: Engine Crossmember Measurements Wed, 13 April 2005 01:33 Go to previous messageGo to next message
This is MA61
http://www.conceptual.net.au/~peewee/uza61/xmember_measurements.JPG
I'll remeasure it soon, and update the pic, as I think the front and rear side to side is different.
Re: Engine Crossmember Measurements Wed, 13 April 2005 01:34 Go to previous messageGo to next message
This is Robs TT132 (thanks Rob)
http://www.users.bigpond.net.au/rsturzen/tt132.jpg
http://www.users.bigpond.net.au/rsturzen/tt13201.jpg
Re: Engine Crossmember Measurements Wed, 13 April 2005 01:36 Go to previous messageGo to next message
Wilbo666, I think main problem you'll have is finding one where the control arm pivot points are only 535mm apart. Most are 600 and over.. Guess would give you more track width Smile
Sure you got that measurement correct? Even the RA28 celica is 560mm apart.
wilbo666
Re: Engine Crossmember Measurements Wed, 13 April 2005 02:19 Go to previous message
TurboRA28 wrote on Wed, 13 April 2005 11:36
Pretty sure I got the measurement correct, as correct as I can be with a tape measure! I've remeasured it many times as quite a few people are doubting my abilities with a tape measure Confused (agreed I can be quite retarded at times Smile).
Previous Topic:XT130 Hilux Brake Upgrade.What pads should I use?
Next Topic:Brake caliper mounting mods
Current Time: Fri Oct 23 15:15:15 UTC 2026
Total time taken to generate the page: 0.0042409896850586 seconds
