Toymods » General Car Talk » need as much 18RG info as possible
Mr DOHC
need as much 18RG info as possible Wed, 13 April 2005 10:56 Go to next message
i am starting to write a tech article on everything anyone could ever need to know about the 18RG, send me some info that u have that could be well known or a little known secret,
need all info, i will add your name if u supply something i add.
pmelvin@bigpond.net.au
Mr DOHC
Re: need as much 18RG info as possible Fri, 15 April 2005 15:40 Go to previous messageGo to next message
tech article is coming along very nicely, need some more info on heads, more specifically valve sizes and maybe port flows {std ports i mean}.
and if u have a known good power making combo, can you please supply details and power/performance figures please
Re: need as much 18RG info as possible Fri, 15 April 2005 22:34 Go to previous messageGo to next message
the 18RG is a twincam motor. Smile
I have two of them. None of them work good Sad
TurboRG
Nor Calif USA
Re: need as much 18RG info as possible Sat, 16 April 2005 23:46 Go to previous messageGo to next message
Mr DOHC wrote on Sat, 16 April 2005 01:40
Stock intake valve size is 45mm and the exh. is 38mm
I have the stock port numbers somewhere.
let me see if I can find them.
What else do you need?
a good combo.
is what I have in one of my cars(but never finished).
the are should run a mid 14's on the drag strip.
mild port job on the intake side.
cams 304 intake side/ 288 exh.
45mm carbs or better
open up the bore to 92mm
with forged 10.5 to 1 pistons
stock rods
stock crank
good fuel pump
and at lease 2 1/4 to 2 1/2 inch exh. pipe
this should make about 180hp.
on my car I still used the 18RC fuel pump and the
stock 40mm carbs and it make about 160hp.
TurboRG
Nor Calif USA
Re: need as much 18RG info as possible Mon, 18 April 2005 00:40 Go to previous message
here in a dyno chart
of a stock 18RG. it's not mine. but some good info
http://home.earthlink.net/~celica73/oldcelica/dyno .html
http://home.earthlink.net/~celica73/oldcelica/18RG%20Dyno%20Results_files/image004.jpg
Previous Topic:Its that time of year again
Next Topic:best injectors to use on 4age
Current Time: Sat Oct 24 05:16:51 UTC 2026
Total time taken to generate the page: 0.0052189826965332 seconds
