Toymods » Tech & Conversions » Unstopable Leak
ta2272
icon2.gif  Unstopable Leak Wed, 13 April 2005 11:07 Go to next message
I have a lea coming from the rear main of the gearbox i already pulled it out and replaced it twice,
The first time i thought i just put it in on a angle but i had my gearbox out of the car and i replaced it again and made sure it was perfect.
Yet it still leaks, just wondering what you guys think as i dont know what to do now.
Jason
Re: Unstopable Leak Wed, 13 April 2005 11:13 Go to previous messageGo to next message
check your tailshaft yoke for wear, as that is the sealing surface.
ta2272
Re: Unstopable Leak Wed, 13 April 2005 22:58 Go to previous messageGo to next message
i did look at the tail shaft yoke and it did seem to be fairly good anyhow i prob didnt do a thourough check of it so ill pull it out,
say if it worn abrassed or whatever im expecting what do you think i should do, give the yoke a lite sand and cleanup and reinstall or find another yoke.
it is a custom tailshaft is it possible to just replace the yoke if it comes to this?
Jason
GefGef
January 2005
Re: Unstopable Leak Thu, 14 April 2005 06:35 Go to previous messageGo to next message
Check for play in the output shaft. A shagged bearing causing too much play could cause a leak.
Also, your gearbox should have some type of breather. Check it is not blocked.
Geoff
Super Jamie
On Probation
North East NSW
Re: Unstopable Leak Thu, 14 April 2005 06:43 Go to previous message
yeah i get this too. after a couple of new seals, i came to the conclusion it was one of the two things gefgef mentioned. one day i'll rebuild a gearbox and drill a 1mm hole in the top plate for a new breather, until them i'm just living with it Smile
Previous Topic:3sgte ignition failing
Next Topic:4AGE QUESTIONS
Current Time: Fri Nov 20 06:48:21 UTC 2026
Total time taken to generate the page: 0.0045359134674072 seconds
