Toymods » Tech & Conversions » ignition barrel RA-23
Petes76celica
ignition barrel RA-23 Wed, 13 April 2005 12:12 Go to next message
hey guys i think the ignition barrel is faulty in my car as a couple of days ago i would have to keep the key turned to keep the car running then it fixed itself and now its doing it agian i was wondering how hard it is to actully change it over with the spare i have.
Pete
Re: ignition barrel RA-23 Wed, 13 April 2005 13:12 Go to previous messageGo to next message
i think you can remove the switch part on the back of the barrel - that where the problem might be - problems with the barrel are usually indicated by key not turning or very hard to insert.
there's 4/6 screws that hold the shroud onto the steering column, they screw in from underneath. you have to remove the steering wheel first. remove horn covers (screws on back of arms), remove horn (be careful not to shot out horn - often eaier to disconnect battery, then bolt holding onto steering wheel will be visible, undo nut, then use a puller (not a hammer) to pull off the wheel.
once off, it'll be obvious how to attack the switch - from memory it's removable but the barrel housing if fixed to the steering column.
to remove the barrel...i think that you put the key in, put it at accessories then shift a locking pin (i think there's a hole on the barrel you poke somethign into) and then pull the guts of the barrel out with key in place.
gold28
Madrid - Spain
Re: ignition barrel RA-23 Mon, 18 April 2005 00:43 Go to previous messageGo to next message
What he said, but there is just a couple of screws holding the switch onto the barrel. You can buy new switchs through places like Auto1 or Repco. I think they are around $20-30.
Re: ignition barrel RA-23 Mon, 18 April 2005 06:00 Go to previous message
you dont need to take the whole steering wheel off though!! I replaced the one in my RA28 aaaaages ago and i dont remember having the steering wheel off....
once you have the steering column plastic covers off, you can see the switch part of the ignition barrel with the wires coming off at the opposite end of the barrel to where you insert the key. One phillips head screw and she is removed from the barrel, and then unplug the 6 pin plug that is at the end of the wires coming off the switch (should only be 20cm long) ... and now replace.
Previous Topic:thicker head gasket
Next Topic:Small amount of water ontop of overflow bottle
Current Time: Tue Sep 15 03:23:48 UTC 2026
Total time taken to generate the page: 0.005173921585083 seconds
