Toymods » Tech & Conversions » Clutch problems on an AE102r
Dunno
Clutch problems on an AE102r Wed, 13 April 2005 13:35 Go to next message
Hi forum guys and girls, ive got an issue with my clutch in my AE102r 7afe, sometimes it likes to change the friction point for no particular reason, and when this happens, the pedal freeplay also changes as well. Does anyone know what the problem is or experienced any problems like it before, and more importantly how to fix it lol... Thanks
Johnny
Sydney, OZ
Re: Clutch problems on an AE102r Thu, 14 April 2005 14:01 Go to previous messageGo to next message
bad master cyl, slave or air lock.
mk1sc
Re: Clutch problems on an AE102r Thu, 14 April 2005 21:33 Go to previous messageGo to next message
possibly, the freeplay rod is not adjusted properly holding the piston over the expansion port
when initally driving its normal but as soon as fluid heats up and cant get to the reservoir, fluid will push against the other way, your friction point will be higher and you will feel pedal real tight. bad enough, the clutch will drag and slip
to fix it just loosen up the rod abit at a time and test drive it
roids70
Tasmania, Evandale
April 2005
Re: Clutch problems on an AE102r Fri, 15 April 2005 00:46 Go to previous messageGo to next message
it is quite possible there is air passing by the slavecylinder rod and changing the position of were it engages and disengages, i had that problem in one of my cars, and all it needed was a new rod iin the slave cylinder with a new seal on it
Dunno
Re: Clutch problems on an AE102r Sat, 16 April 2005 10:20 Go to previous message
Thanks guys, cause im a newbie, most of the stuff u said made no sense to me but yeah, it only happens every so often and it usually 'fixes' itself afta like a short drive. Again thanks for the input.
Previous Topic:4A-C going balistic at 90-105km/h
Next Topic:4age light knocking on start....help
Current Time: Sat Oct 31 13:22:11 UTC 2026
Total time taken to generate the page: 0.0047590732574463 seconds
