Toymods » Tech & Conversions » 4A-C going balistic at 90-105km/h
Tofuboi
Sunbury, VIC
4A-C going balistic at 90-105km/h Wed, 13 April 2005 18:01 Go to next message
Hey guys, my 4A-C in my AE82 is being really dodge lately. We've had it checked and checked over and over again by mechs and no one knows whats going on.
Here's what goes on from my perspective.
You're driving along , slowly making your way to 100km/h as it does. Then out of nowhere, the engine will start to slow down, without you doing anything! It starts to pull back furiously on you as if it hates going faster than 80-105 km/h. This happens randomly but its really annoying. Sometimes it gets to the point of just seizing to go any further and just stalls at that speed... revs just drop to 0 and thats it. game over. but i can just chuck it into neutral and start it again no problems, put it into drive and away we go, while rolling to a halt. well. can someone help? we've had the fuel system looked at and its 100% fine we've had services done on it we've had almost everything done!
mind you, ita an automatic Razz just in case that gives ya any idea of whats going on.
shinybluesteel
melbourne
Re: 4A-C going balistic at 90-105km/h Wed, 13 April 2005 23:40 Go to previous messageGo to next message
i have seen this exact problem before,
solution: replace your fuel filter, should cost less than ten bucks.
just read your post, this might have been checked already.
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 03:14 Go to previous messageGo to next message
Yeah, sounds like fuel to me.
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 03:17 Go to previous messageGo to next message
Actually, how does it drive?
Does it drive fine from 0-100, regardless of throttle?
ie, you can baby it up to 100, and then it will stuff up
As well as going full throttle from 0-100, and then it will stuff up?
If so, I'd be looking at the drivetrain, maybe the auto is locking up or not pumping.
Try hold it in 2nd until redline, see if its any different.
Kyosho
Wollongong
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 04:34 Go to previous messageGo to next message
CrUZsida wrote on Thu, 14 April 2005 13:17
I was thinking the exact same...
When normally driving, you should pass through the exact same rev ranges and throttle positions and hence, if it's a fuel problem, it will happen at all gears...
I'm thinking your top gear is seizing up at the high speeds...
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 04:37 Go to previous messageGo to next message
had same problem but at all speeds ended up being a pin hole in the top of a piston Sad
StockAE86
Outer Sth East burbs, VIC
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 04:47 Go to previous messageGo to next message
Might be a good idea to check your points in the distributor too. Mine had a similar problem but not quite as savage and thats how i fixed it.
Tofuboi
Sunbury, VIC
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 08:40 Go to previous messageGo to next message
Baby it up to 100, its fine until around that speed then it will randomly happen.
Full Throttle to 100, 1st to redline change is fine, 2nd to redline change you'll get to around 5,000rpm or so and then theres no more push, it will start doing it. which is about 95km/h.
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 08:46 Go to previous messageGo to next message
I'd be looking at the auto.
Either try and find a cheap replacement, or at least give it a fluid flush (check the levels first)
Tofuboi
Sunbury, VIC
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 08:51 Go to previous messageGo to next message
CrUZsida wrote on Thu, 14 April 2005 18:46
The gearbox has just been replaced about 7 or so ago as the old one was just gone... It's a 2nd hand one though but it was checked before it was put in. However recently there was a hole in a pipe on the gearbox which supplied transmission fluid around it, and we didnt know so the car was running on pretty much no fluid whatsoever for a good week or so until we noticed leaking from the bottom of the car.
Currently its got brand new fluids in it and its all good, but the problem still persists.
[Updated on: Thu, 14 April 2005 08:52]
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 08:54 Go to previous messageGo to next message
Was the problem around before that? or did it only happen after that?
If so, how long after?
Tofuboi
Sunbury, VIC
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 08:57 Go to previous messageGo to next message
I noticed the problem occur one evening when I was driving home... I didnt know what it was, the problem was going for a few weeks before we actually noticed there was almost zero fluid in the transmission and the leaks, then it was 2 weeks after we refilled the transmission with tranny fluid and actually got it checked by an automatic transmission specialist who said there was a pipe leak.
tripod
January 2005
Re: 4A-C going balistic at 90-105km/h Thu, 14 April 2005 12:07 Go to previous messageGo to next message
have a look at the exhaust system if you have a loose or rusted baffle in the muffler it will severly restict exh flow resulting in loss of power and or stalling
EldarO
Perth, WA
Re: 4A-C going balistic at 90-105km/h Fri, 15 April 2005 14:13 Go to previous messageGo to next message
if you put new fluids in, then it started shitting itself, why are you even asking? its the fluids.
problems dont just occur, they need triggers, think about what happened to the tranny/engine before it started doing this.
Eldar.O.
edit: speeling
[Updated on: Fri, 15 April 2005 14:14]
flyinwall
Toowoomba
March 2005
Re: 4A-C going balistic at 90-105km/h Sat, 16 April 2005 11:08 Go to previous message
ok it sounds like you have shit in your fuel tank! What it sounds like is that something is getting caught at the pickup in the fuel tank. Remove your fuel line after the fuel filter and get the trusty air compressor out and blow the line back through to the fuel tank this will clear the fuel line and it should stop your problem.
Previous Topic:can i adapt a 4AGE16v head to a 4AFE block
Next Topic:Clutch problems on an AE102r
Current Time: Sat Oct 31 03:43:55 UTC 2026
Total time taken to generate the page: 0.1326060295105 seconds
