Toymods » Tech & Conversions » Knocking noise in 7M-GE
eluthria
Knocking noise in 7M-GE Thu, 14 April 2005 00:20 Go to next message
Guys,
I drive an MX83 with the standard 7M-GE. I'd be greatful if anyone could shed some light on a knocking noise that has just began.
Since last night the engine has seemed rough to start and idle even after warmed up. This morning I also noticed a loud knocking noise which began after about 20 minutes into my journey and appeared to be more predominant at idle. After pulling over the noise had subsided a little thought it was still present. The noise appeared to be coming from behind the cam-belt cover. Once I'd reached my destination the noise had all but disappeared however.
Help?
Thanks!
bbaacchhyy
Re: Knocking noise in 7M-GE Thu, 14 April 2005 00:24 Go to previous messageGo to next message
eluthria wrote on Thu, 14 April 2005 09:50
Guys,
Help?
Thanks!
Rod knock ?
What is the oil level like ? History of the motor/servicing ?
Michael B
eluthria
Re: Knocking noise in 7M-GE Thu, 14 April 2005 00:58 Go to previous messageGo to next message
Quote:
Rod knock ?
Is that the cams moving backwards or fowards to create a knocking sound? Sorry my knowledge is rather limited Embarassed In any case though the sound seemed like it was coming from directly behind the cam-belt cover rather than further back in the head.
I check the oil about two weeks ago it was a little down so I topped it up. Generally it only requires one top up between services. I service the car every 10,000 or 6 months. The engine is a low millage japanese import which was installed almost a year ago now. I'm told it came from a Japanese 97 Supra (don't go there). Mechanic who installed the engine and does work on the car though is honest and seems to know his stuff. Since installation I have had no problems at all with the motor.
Allan
Re: Knocking noise in 7M-GE Thu, 14 April 2005 02:30 Go to previous messageGo to next message
get us a vid clip
ed_ma61
Lost in the K hole
Re: Knocking noise in 7M-GE Thu, 14 April 2005 03:21 Go to previous messageGo to next message
rod knock = crank bearing on the way out
7m's dont like low oil pressure at all, and bearings flog out easily
eluthria
Re: Knocking noise in 7M-GE Thu, 14 April 2005 04:01 Go to previous messageGo to next message
I've just had a closer look at things and the problem seems to have gone away at the moment.
Here's some detail on what I've just done now:
A soft knocking noise began not too long after I started the engine but went away fairly quickly after reving the engine a little. The engine also seemed reasonably smooth unlike it had this morning.
I turned the engine off and I check the radiator water (from the radiator) and noticed it was very low so I put about a litre or more of water in. The over flow bottle was almost empty so I added some collant/water there too. I checked the oil and that was actually touching 'L' so I filled it up till it was touching the 'H'. I opened the heater and started the engine again and let it run for a while. The radiator cap was still off and I'd say over 50% of the water I put in was pushed out again not sure why?
I replaced the radiator cap then ran the engine for a good 15 minutes with a bit of random reving and the AC both on and off but the noise didn't return. I then took the car for a short drive and it seemed very smooth and there was no knocking sounds during or after the drive.
I hope this detail might help one of you guru's pin down what's going on with my little beasty.
Quote:
get us a vid clip
No problem. Which bit would you like a clip of, the engine while it is making the knocking sound?
I imagine that if rod knock was related to the crank then it would be pretty loud and meaty right? Should a bearing need to be replaced, would it be a real pain in the bum job? What's likely to cause low oil presure besides a faulty oil pump?
Allan
Re: Knocking noise in 7M-GE Thu, 14 April 2005 04:06 Go to previous messageGo to next message
eluthria wrote on Thu, 14 April 2005 14:01
Quote:
get us a vid clip
yep
dingaling
tas
Re: Knocking noise in 7M-GE Thu, 14 April 2005 10:33 Go to previous messageGo to next message
7m engine from a 97 supra, pfff i know you said not to go there, but just relize your mechanic doesn't know what he's talking about.
Boy i'd love to be able to ring him up and set him straight with his mis-information.
joash
March 2005
Re: Knocking noise in 7M-GE Thu, 14 April 2005 11:31 Go to previous message
dingaling wrote on Thu, 14 April 2005 20:33
shoulda put a 1J in her
about the coolant. the reason it pushed a heap back out, is because the coolant system is all pressurised. as i'm sure you know water (and many other things) 'expands' as it gets hotter, so as your engine warms up, the coolant becomes pressurised. that's why you have a coolant overflow tank. that is also why the bottom of your radiator cap has a spring in it. as the pressure bcomes to great, it pushes up the little seal thingy, and lets the water flow out, instead of blowing your radiator to bits.
is the knock more of a 'knock' as in a rather deep almost 'thud' kind of a noise. or more like a 'tap'
does it sound likes it in the bottom end or the top
yes if it is a crank-shaft bearing.. it is most likely a 'pain in the bum' kind of job... i cant really remember what the sump on the 7m's are like, so don't know if you could get it off while under the car or have to take the engine out.. but you will most probably have to take the engine out anyhow.
if it's only a crankshaft bearing, you could probably just rip uot the crack shaft, get it ground and put oversize bearings in..
if it's more than that.......
Previous Topic:Air Flow Meter Tech
Next Topic:Quik brake up-grade question
Current Time: Fri Nov 20 11:13:37 UTC 2026
Total time taken to generate the page: 0.0065169334411621 seconds
