Toymods » Tech & Conversions » 3sgte ignition failing
berad
3sgte ignition failing Thu, 14 April 2005 04:57 Go to next message
i have a problem my car wont start... it will turn over and squirt fuel into the engine but no spark. so i pulld a plug out to see wats goin on. wen i turn the key over to start it wont spark , but wen i let the key go back to the "on" position it will spark once or twice but sometimes not at all
and when the key is on there is a relay somewhere behind the kick panel that will click a few times then stop then click a few more times etc
so i replaced the leads , coil , dizzy , rotar button , tried another ignitor
ive also checkd the contunity of the ignition wires from ecu to the loom plugs... it is runin an ems stinger ecu although this shouldnt matter... all my maps r still on there so no it hasnt lost the maps
could someone throw me a few options
all i can think of is maybe a wire near the ignition barrel or in the dash is shorting out , lost its earth or is just broken
does this sound right?
[Updated on: Thu, 14 April 2005 05:03]
JustenGT4
Re: 3sgte ignition failing Thu, 14 April 2005 06:52 Go to previous messageGo to next message
I'd bet money on the Stinger as the cause...maybe the ignitor outputs are fried?
berad
Re: 3sgte ignition failing Thu, 14 April 2005 07:53 Go to previous message
maybe not just had a stuff around with the kick panel fuse box turnd the key and jiggled the fusebox... and it fired each crank but wouldnt stay runnin s my guess is a wire has a loose connection would that make sense?
Previous Topic:will ma70 brake booster bolt on ra23
Next Topic:Unstopable Leak
Current Time: Fri Nov 20 06:56:16 UTC 2026
Total time taken to generate the page: 0.091133117675781 seconds
