Toymods » Tech & Conversions » Air Flow Meter Tech
ra23celica
icon6.gif  Air Flow Meter Tech Thu, 14 April 2005 08:48 Go to next message
Does anyone have some technical information on the inner workings of a typical Toyota AFM ?
I particularly want to find out all the inputs and outputs and how the ECU uses them.
Thanks.
setsuna
Re: Air Flow Meter Tech Thu, 14 April 2005 08:54 Go to previous messageGo to next message
pull one apart.. they are pretty simple.
either a gate, or a hotwire.
google is your friend!
Re: Air Flow Meter Tech Thu, 14 April 2005 08:55 Go to previous messageGo to next message
That Autoshop 101 site should have something.
ra23celica
Re: Air Flow Meter Tech Thu, 14 April 2005 08:58 Go to previous messageGo to next message
Thanks guys - I will look around.
I just took my AFM apart and found 7 pins inside the thing but only 6 pins in the loom plug.
Then I check the part numbers for the millionth time and I have the correct AFM for my car.
Is there a dummy AFM pin in these things ? Mine has one of two black wires plugged into it.......
ed_ma61
Lost in the K hole
Re: Air Flow Meter Tech Thu, 14 April 2005 09:44 Go to previous messageGo to next message
it actually ISNT that simple... No No No
its not just a simple linear increase like youd expect with a potentiometer or something. its more like a recurring step function, and near bloody impossible to interfer with in any meaningful way
ra23celica
Re: Air Flow Meter Tech Thu, 14 April 2005 11:43 Go to previous message
Thanks Ed,
This is what I found out via Google and Autoshop 101.
I also checked why I had 7 pins in the AFM and only 6 in the loom plug, and that is normal for a GZE motor.
Back to the drawing board for the richness problem then !
Smile
Previous Topic:QUESTIONS REGARDING Ke30 axles in a KE10 diff
Next Topic:Knocking noise in 7M-GE
Current Time: Fri Nov 20 11:26:51 UTC 2026
Total time taken to generate the page: 0.0042960643768311 seconds
