Toymods » Tech & Conversions » MA61 Camber Adjustable Rear Cross-member
negative boost
Hobart, TAS
MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 10:18 Go to next message
http://www.onthenet.com.au/~paulp/supra/
Found this while searching one day, and thought that this could be the solution to the problem when lowering the MA61 the rear camber becomes too great. But i just cant quite figure out how it works as theres only pictures on the web page. If anyone has seen this mod before or knows how it works please explain Smile
STR8 2.8
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 10:51 Go to previous messageGo to next message
do a search. this has come up a number of times.
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 10:56 Go to previous messageGo to next message
My MA61 crossmember is currently being modified by the same workshop. It's pretty simple really, they just install eccentric bolts on the trailing arms to allow vertical adjustment, same as the existing eccentric bolts which allow horizontal adjustment (ie for toe).
negative boost
Hobart, TAS
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 11:25 Go to previous messageGo to next message
Oh, fair enough then. Thnx for the info. How much is this costing you by the way?
Tried searching also but couldnt find anything, ill keep searching.
STR8 2.8
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 11:39 Go to previous messageGo to next message
tsk tsk
http://forums.toymods.org.au/index.php?t=msg&g oto=219933&rid=2064&S=11a5d3d2fb4ddf7d8d48 fbf044d3a218
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 11:54 Go to previous messageGo to next message
negative boost wrote on Thu, 14 April 2005 21:25
Dunno yet, still waiting for the shop to get back to me. Hopefully not much though, it's just a couple of bolts and a bit of cutting/welding!
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 11:58 Go to previous messageGo to next message
hrm... this is something i might have to employ on the crown as well. Negative camber on the 130 series at anything below normal ride height is, well, massive.
BlackSupra
Re: MA61 Camber Adjustable Rear Cross-member Thu, 14 April 2005 12:03 Go to previous messageGo to next message
Tell us the price son!
bbaacchhyy
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 01:07 Go to previous messageGo to next message
BlackSupra wrote on Thu, 14 April 2005 21:33
I can't remember how much it was, but the shipping to & from FNQ killed it for me at the moment.
I have a spare rear X-member in the shed waiting to this work done to .....
Edit : I was hoping that Norbs would ask if they do it as a "kit" so I can do it myself.... Cool
[Updated on: Fri, 15 April 2005 01:08]
Allan
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 01:32 Go to previous messageGo to next message
dosent look too scarey at all got a pic of the stock x-member? (holds up drill and die grinder)
bbaacchhyy
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 01:57 Go to previous messageGo to next message
Allan wrote on Fri, 15 April 2005 11:02
It isn't too scary, but why reinvent the wheel. Get them to make up another set of brackets when they do Norbs, send me the details to put them on in the correct position, I'll send them some money and I'm happy as a pig in shit !!!
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 02:10 Go to previous messageGo to next message
I already asked about this, they said they weren't willing to do it. I could possibly get you a pair of camber bolts though, the rest is just cutting/welding as far as I know?
Oh and since when is the Gold Coast "FNQ"? Laughing
bbaacchhyy
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 02:26 Go to previous messageGo to next message
Norbie wrote on Fri, 15 April 2005 11:40
FarkeN afr enough away from adelaide Queensland
Pity about the bits though Sad
I'll have to see what I can cobble up myself then. I have plenty of Camber bolts from my MS123 Crown excusions, so will base it on this.
takai
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 02:44 Go to previous messageGo to next message
Its not that hard to do. I believe Kmac sell the bolts, and all you have to do then is slot the existing brackets, and also make up a second set of brackets to reinforce the first ones.
While its not an MA61 the Datto1600 guys do exactly the same thing. Tim did this to his: http://www.group3j.com/rear_xmember_fab.html
bbaacchhyy
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 02:56 Go to previous messageGo to next message
takai wrote on Fri, 15 April 2005 12:14
Thanks for the link.
It won't be that hard, but if someone already has the measurenments of the size of the bracket, slot position and size, why reinvent the wheel !!!
Norbs, any pic/measurements will be greatly appreciated
Michael B
negative boost
Hobart, TAS
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 03:51 Go to previous messageGo to next message
Whoa, thank you very much! Thats tonnes of infomation there, ill have to try and sift through it all in detail some other time. And Norbie keep us updated please!
STR8 2.8, i cant believe i didnt find that thread, thnx.
Celia-Sue
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 03:59 Go to previous messageGo to next message
Racing Datsuns do this all the time - surely you could fining someone who works with 1600s on the track to do this for you cheap?
takai
Re: MA61 Camber Adjustable Rear Cross-member Fri, 15 April 2005 23:08 Go to previous message
bbaacchhyy: for the precise reason that shipping costs a ton. Thats all the reasons i can think of.
Previous Topic:difference between 1G-GTE & 1G-GEU
Next Topic:KE70: rack and pinion or steering box?
Current Time: Fri Nov 20 07:32:46 UTC 2026
Total time taken to generate the page: 0.0080389976501465 seconds
