Toymods » Tech & Conversions » 18rgeu cam timing
2syco
18rgeu cam timing Thu, 14 April 2005 12:47 Go to next message
i am putting together an 18rgeu from scratch and need to know at top dead center what degrees should the intake cam be positioned at and at bottom dead center what the exhaust cam should be at?
Re: 18rgeu cam timing Thu, 14 April 2005 21:48 Go to previous messageGo to next message
use the timing markers on the cams.
Steve M
Re: 18rgeu cam timing Fri, 15 April 2005 03:56 Go to previous messageGo to next message
Witzle is right, but maybe some more details would help.
Each cam has a 5mm wide notch out of its thrush flange. This is the timing mark indicated by The Witzl.
At TDC for cylinder no.1 both the notches on the intake and the exhaust cam should be in the 12:00 position, ie. exactly vertical.
I assume you know how to use the timing pin and the adjustable timing cog so I won't explain that.
If you need to know any tightening torques, let me know which ones and I'll check the book.
brett_celicacoupe
townsville NQLD
Re: 18rgeu cam timing Fri, 15 April 2005 09:27 Go to previous messageGo to next message
i didnt need to play with the timing pins at all. i joined the chain when all the marks were lined up...works fine
brett
joecoolmk2
Re: 18rgeu cam timing Fri, 15 April 2005 13:13 Go to previous messageGo to next message
my 18R-G is acting like is has a rev limiter, it stops revving at about 5600rpm, as well as being sluggish in low revvs, i'm guessing it's the distributor, which is a twin point malory with no vacuum advance. i know it's not fuel and not restrictive air filters. anybody got any advice?
i was gonna machine a new dizzy housing with vacuum advance to better the ignition timing control.
Re: 18rgeu cam timing Fri, 15 April 2005 13:16 Go to previous messageGo to next message
might be easier to get a 18GUE igniter - comes with vacuum advance plus pickup to drive an igniter.
joecoolmk2
Re: 18rgeu cam timing Fri, 15 April 2005 13:20 Go to previous message
i live in tassie, 18R-G parts are very scarce and don't come cheap, plus i'm an apprentice fitter/turner, so making my own will be easier and it'll give me something to do in spare time.
Previous Topic:TA23 Diff conversion
Next Topic:Susp help needed
Current Time: Fri Nov 20 16:35:30 UTC 2026
Total time taken to generate the page: 0.087480068206787 seconds
