Toymods » Tech & Conversions » Couple of Soarer questions
ytri
Preston
Couple of Soarer questions Fri, 15 November 2002 04:34 Go to next message
Ok, first one. Occasionally, whenever runnig more than stock boost it hits a cut off, and an orange warning light shows up on the dash. This stays on for a few seconds then goes off. It doesnt happen all the time, sometimes it will run fine at a cretain amount, then another day, at the same level, it will cut out. Whats going on there??
Second, my car has kinda half the exhaust done. Its 3" off the stock Y piece, untill it sits just under the car, then it goes to something like a 1.75 - 2.25 pipe with a cat (dodgy compliance place peoples) then its 2.5" where it splits into 2. Should i replace that small bit of pipe and cat with 3" now? I know its a stupid question but is it worth it, or should I spend the cash elsewhere??? Will there be any noticeable difference?
Soarer
Wollongong
Re: Couple of Soarer questions Fri, 15 November 2002 06:46 Go to previous messageGo to next message
Have you played with the boost settings, cos on mine with a 3" exhaust from the factory Y pipe to twin mufflers, it peaks close to 13 psi (cutoff is 14.7). I imagine you are hitting boost cut on really cold nights ? Cos this is when spiking occurs most.
ytri
Preston
Re: Couple of Soarer questions Fri, 15 November 2002 06:59 Go to previous messageGo to next message
Boost is set at 11 psi. It doesnt happen all that often. Sometimes it will run fine for a few weeks, then out of nowhere it will happen once or twice. Happens in all kind of conditions too. Hot days, cold nights etc....
BlakeNZ
Re: Couple of Soarer questions Fri, 15 November 2002 23:17 Go to previous messageGo to next message
You are hitting boost cut-no question about it.You require a boost cut lifter.
replacing that skinny part of exhaust and cat will give a very worthwhile power gain.
ytri
Preston
Re: Couple of Soarer questions Sat, 16 November 2002 03:15 Go to previous messageGo to next message
I have no doubt about the boost cut, I guess im more trying to figure out why that orange warning light comes on sometimes. What is it??
ChuckLandwehr
Re: Couple of Soarer questions Sat, 16 November 2002 11:04 Go to previous messageGo to next message
Which orange warning light buddy?, let me know, and I will check it out in my Soarer manuals.
If it looks like a small muffler with wavy lines above it, that is your cat overheat light, and can operate when fuel cut leans out the exhaust flow!
Regards Chuck
Soarer
Wollongong
Re: Couple of Soarer questions Sat, 16 November 2002 13:29 Go to previous messageGo to next message
It's odd that you are hitting boost cut and are running lower boost than me. My boost level after is stops spiking is 12psi.
Never have I hit boost limit in my car.
Tis a weird one.
Cheapest boost cut remover is a diode inline with the MAP sensor.
27 cents of fun Razz
ytri
Preston
Re: Couple of Soarer questions Mon, 18 November 2002 22:43 Go to previous messageGo to next message
Its not the red one that looks like a muffler, its the one underneath it. Its a sort of weird shape, with a small flat line at the top, and one on the side as well, and it lights up orange.
Pumpkin
Toymods Board Member
Re: Couple of Soarer questions Mon, 18 November 2002 23:01 Go to previous messageGo to next message
According to the manual, thats the exhaust overheat light!! Wierd!!
ytri
Preston
Re: Couple of Soarer questions Mon, 18 November 2002 23:14 Go to previous messageGo to next message
Ok. Well anyone have any ideas why it comes on??
BlakeNZ
Re: Couple of Soarer questions Tue, 19 November 2002 00:11 Go to previous messageGo to next message
I reckon you get the overboost "bong" and jap words come on screen saying "boost pressure malfunction".
BlakeNZ
Re: Couple of Soarer questions Tue, 19 November 2002 00:14 Go to previous messageGo to next message
however,if you were leaning out,the exhaust would become very hot,possibly triggering the overheat sensor.perhaps get your air/fuel ratios checked by a mechanic.
ytri
Preston
Re: Couple of Soarer questions Tue, 19 November 2002 00:16 Go to previous messageGo to next message
I had them checked a couple of months back, and it was running slightly rich. Maybe time to go back.....
[Updated on: Tue, 19 November 2002 00:19]
Re: Couple of Soarer questions Tue, 19 November 2002 00:28 Go to previous messageGo to next message
Is it perhaps a function of the really nasty exhaust piece building up too much heat in the exhaust?
ytri
Preston
Re: Couple of Soarer questions Tue, 19 November 2002 00:30 Go to previous messageGo to next message
I was thinking that, but my friend has a completely stock exhaust on his and runs 13psi with no probs. Im getting that bit replaced on saturday so i'll see if that helps! Thanx heaps guys
ytri
Preston
Re: Couple of Soarer questions Wed, 27 November 2002 22:17 Go to previous messageGo to next message
OK, replaced that part of the exhaust, and everything was all fine. Ran perfect with stock boost or 12psi. Turned it down to 10psi and been driving all week without a problem until today. Didnt floor it, just gave it a little. Exhaust light came on, and engine cuts. So, any more ideas?
ytri
Preston
Re: Couple of Soarer questions Sun, 01 December 2002 21:51 Go to previous messageGo to next message
Sad Anyone???
Soarer
Wollongong
Re: Couple of Soarer questions Mon, 02 December 2002 05:52 Go to previous messageGo to next message
Intermittent fault in the MAP sensor ?
Clutching at straws now. It's a weird one indeed.
Manny
Re: Couple of Soarer questions Mon, 02 December 2002 10:37 Go to previous messageGo to next message
Which Soarer dash do you have - with or without the LCD display bottom centre?
ytri
Preston
Re: Couple of Soarer questions Mon, 02 December 2002 12:25 Go to previous message
I got the dash WITHOUT the LCD display. What are you thinking??? I think i should just give up and take it to some work shop Sad
Previous Topic:18RGeu coil in 18Rc? vice versa.. HELP
Next Topic:RA28 alternators
Current Time: Mon Oct 12 17:34:51 UTC 2026
Total time taken to generate the page: 0.073375940322876 seconds
