Toymods » Tech & Conversions » no spark outa tha coil 20valve silver
LAA.80E
The realist ghetto area P...
April 2005
no spark outa tha coil 20valve silver Fri, 15 April 2005 02:48 Go to next message
iv just put in a silver top onto a ae92 sx for a mate but there aint no spark outta the coil and iv replaced the coil and the new one works along with igniter still no spark sumone please help us out??? thanks heapssss
Johnny
Sydney, OZ
Re: no spark outa tha coil 20valve silver Fri, 15 April 2005 13:02 Go to previous messageGo to next message
coil could be wiried in wrongly.
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Wed, 20 April 2005 21:58 Go to previous messageGo to next message
its not the silvertopp is for a mate of mine and he wants to run his sx loom onto the 20valve along with the sx ecu??!!!!!
and iv done just about everything but nooooo spark outta the coil iv changed igniters but still no luck , could it be crank angle sensor???
sideshow
Re: no spark outa tha coil 20valve silver Wed, 20 April 2005 22:34 Go to previous messageGo to next message
y are u runnin the sx loom
how do u expect to run a 20v on a 4age ecu
dsome poeple are so bloody dodgey
anyway check if the injectors are pulsing
if they are then the ctank sensor is ok
is the ignitor earthed
but if u r tryin to run the 20v on the original 4age wiring and ecu then yr just wasting yr time
it might eventually work but it will be a waste of time
what bout the vvt whats goin to control it
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Wed, 20 April 2005 23:59 Go to previous messageGo to next message
to be honest with you guys i dont know how th phuck itll run but it aint mine i charged the bloke fo me to out it in and i have and dats dat ... so i really dont care wat he gunna be running..... ohhh wellll
Johnny
Sydney, OZ
Re: no spark outa tha coil 20valve silver Thu, 21 April 2005 13:15 Go to previous messageGo to next message
my thought's exactly! Anyway, the 16V triggers have only four teeth with one trigger tooth, and the 20V has 24 teeth and one trigger tooth, So ask yourselves how is the ECU able to tell the difference? My gut feeling here is the output is showning 7 times more pulses and is confusing the ECU and it's just going "Yeah right! WTF"... Just run the 20V ECU!
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 00:00 Go to previous messageGo to next message
AYYYYYYMEEEENNN too that , stuff it , i was thinkn of buying a 20v blacktop front cut.., but i have 3 4age's at homand im working one of em wht you guys rekon get a 20vblacktop and work that up or keep the 4age??
gearb0x
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 03:00 Go to previous messageGo to next message
Johnny wrote on Thu, 21 April 2005 23:15
The smallports use a 24/1 tooth setup as well, my thoughts are while u may be able to get the engine to run, ur spark/fuel maps will be way up the shit (not tooo bad i would think) and you will have to find another way to switch the vvt on and off
Sounds like a pointless excercise, for best results go find the right ECU Smile
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 03:47 Go to previous messageGo to next message
Thanx peoplezzzzzzz:)Very Happy
Johnny
Sydney, OZ
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 04:02 Go to previous messageGo to next message
I was think last night about this and there is a way around the problem, we use a 20V setup on our 7afe, but we use an autronic, so this doesn't car what we use. But my point is that if you use the 4AFE dizzy it has a 4/1 setup same as the 16V and does if the hole/cam of the 20V, the only difference is that the location of the tigger tooth will have to be the same as the 20V, which mean you'll have to move the dizzy to match this and then lock it in. This may then work... Well B/top? ok standard, but not good for working them stupid. You can adapt all the good stuff like throttle bodies, cams, flywheel to a S/top, which is what we are in the process of doing.
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 06:30 Go to previous messageGo to next message
So your telling me if i bought a b/top 20v pulled tha head off port polished the exhaust outlets slightly bigger cams in duration and lift if possible , shave bout 30 to 40 thou off tha head high flow injectors, match ported custom extractors and run a stinger4 on it , it aint gunna go hard???? thats wat im gunna be doin wid tha 16v but im not sure if i should through forgies in for future turboing? watchyas rekkon?
Johnny
Sydney, OZ
Re: no spark outa tha coil 20valve silver Fri, 22 April 2005 11:18 Go to previous messageGo to next message
No, we just get Better results and reliablity from the S/top. The combo we use are B/top throttles+manifold, b/top flywheel and yager cams (260 deg 8.8 mm lift)and S/top head and rods, Forged Pistons, 13:1 comp, motec,etc Good for 150fwhp. B/top rods couldn't handled constant redlining, and the rules for this engine state factory rods. The watered down verison uses similar gear but has standard 20V pistons and only 11:1 comp through shaving, b/top cams in which only the intake has slightly higher lift (8.2mm vs S/top 7.9mm), exhaust cams are are identical 250deg,120fwhp; both use customed made and designed headers. Ported, shaved b/top, same pipes made 120fwhp, So why pay the extra $$$?? Most people Buy a B/top to say "hey, I've got a B/top!" That nice's, I've had one for nearly six years and costed half the price they are today! And I ended up converting it from a 6-spd to and auto for the missus! That was a struggle.... The problem with the B/top is the rods and "squish" areas in the head, Shaving the crap out of a S/top head gives much more comp if and when you do the same amount to a B/top. Also the S/top has a lot more meat to play around with in the ports, So a really good porter are able to get better flow rates from the S/top head, seen many times.
LAA.80E
April 2005
Re: no spark outa tha coil 20valve silver Sat, 23 April 2005 13:42 Go to previous message
thanx heaps on tha info... well im continouing to port and polish my 16v i was just doing it bout 20 minutes ago nuthn betta to do, but wat spins me out the most is the valves on the exhaust side they are way to small i figure .. and wat iv put together is port polish exhaust only 20thou bigga valves (exhuast) stiffer valve spring forged high comp pistns 3mmcopper head gasket and i wanna through on a turbo and etc willing to blow big bucks on the phukka
Previous Topic:controlling boost spikes
Next Topic:wires on front left of 4age 20v silver
Current Time: Mon Oct 19 17:50:12 UTC 2026
Total time taken to generate the page: 0.00685715675354 seconds
