Toymods » Tech & Conversions » AE86 Rollcage specifications
Switch to threaded view of this topic Create a new topic
Phrostbyte
Frankston, Victoria
AE86 Rollcage specifications Fri, 15 April 2005 02:49 Go to next message
My cousin has just bought an AE86 and is currently doing a blacktop turbo conversion... anyway to the point.
He asked me this morning if I knew a source to get every single tiny measurement on an AE86 roll-cage and even a blueprint or something of the sort if possible. He has a place next door to the workshop he is working on his car on that manufactures steel frames etc and has done rollcages before, just needs the measurements....
Thanks peeps,
Kev.
studman
On Probation
Charnwood
March 2005
Re: AE86 Rollcage specifications Fri, 15 April 2005 04:34 Go to previous messageGo to next message
dummest kwestion evah!
kut da hooped legs off a tramampoline and weld them into da sprintah for a cage. mezshurments will be spot on
MR 1JZ
Re: AE86 Rollcage specifications Fri, 15 April 2005 05:24 Go to previous messageGo to next message
are you serious...
Right now I am clicking on this button right here ---> Ignore all posts by the above moron
you seriously need to think about your posting attitude and maybe using some correct grammar and spelling.
Joshstix
Toymods Vice President
Re: AE86 Rollcage specifications Fri, 15 April 2005 05:27 Go to previous messageGo to next message
studman wrote on Fri, 15 April 2005 14:34
Learn to use English and stop being an idiot or stop using this forum.
You are now on probation, if there is any reason for a moderator to need to warn you again you will be banned from the forum, along with the IP address you post from.
Sam_Q
S.E suberbs, Vic
Re: AE86 Rollcage specifications Fri, 15 April 2005 15:18 Go to previous messageGo to next message
I dont beleive its possible to make a cage for an ae-86 with just measurements. Sounds like a dreamer. Good luck to him I say, reality is a bitch
boudan
Re: AE86 Rollcage specifications Fri, 15 April 2005 16:40 Go to previous messageGo to next message
It sounds reasonable enough...
the inside of every ae86 will share the same dimensions, I think he's looking for mock plans tho,
Roll cages are not something that can be knocked out by everyday joe.. From my own experiences you'll need to consult an engineer before any cutting / bending / welding starts...
Do you want a half cage or full cage, do you know what points of the car the cage must be mounted to, to actually perform any use..materials, welds, bends, permanent or removable..
Either way, if its a road car, you'll need tickets for legal reasons...
Redwarf
February 2005
Re: AE86 Rollcage specifications Sat, 16 April 2005 04:05 Go to previous messageGo to next message
To my knowledge, half cages will shortly not be able to get a CAMS logbook. (Requirement if you're going to do any serious racing.)Get a CAMS manual and build it to that. You can also get further info if required out of CAMS. Once again, if it's going for a logbook, the manufacturer has to fill out a form stating all material specs and certify that it complies to specs. CDS is a bitch to bend, and unless this guy has some serious equipment, and knows what he's doing, take it to a cage builder and get it done by someone who does them everyday. I did, because I know what my life is worth.
P.S: Half-cage for Half-wits! Wink
Joshstix
Re: AE86 Rollcage specifications Sat, 16 April 2005 05:06 Go to previous message
This thread is being locked due to being a duplicate of the other thread started by the same person.
Previous Topic:bubbling and overheating problem on 1JZ!!! :(
Next Topic:difference between 1G-GTE & 1G-GEU
Current Time: Fri Nov 20 09:23:46 UTC 2026
Total time taken to generate the page: 0.0059700012207031 seconds
