Toymods » Tech & Conversions » AE86 Rollcage specifications
Phrostbyte
Frankston, Victoria
AE86 Rollcage specifications Fri, 15 April 2005 02:59 Go to next message
My cousin has just bought an AE86 and is currently doing a blacktop turbo conversion... anyway to the point.
He asked me this morning if I knew a source to get every single tiny measurement on an AE86 roll-cage and even a blueprint or something of the sort if possible. He has a place next door to the workshop he is working on his car on that manufactures steel frames etc and has done rollcages before, just needs the measurements....
Thanks peeps,
Kev.
Henn
Rosanna, Melb
Re: AE86 Rollcage specifications Fri, 15 April 2005 03:33 Go to previous messageGo to next message
As far as I know there really isn't a recipe for a rollcage as such. Choose the design you want (The CAMS manual has a bunch of homologated ones) then bend up the tubing and check it against the shape of the car, then bend the tubing more and re-check, then more bending and checking etc etc etc... Then weld that section in and move onto the next section.
So each cage is custom made to the car. Also, all cars are slightly different shapes and dimensions, so the perfect cage in one car may foul on parts of another car of the exact same model.
Hen
takai
Re: AE86 Rollcage specifications Fri, 15 April 2005 04:26 Go to previous messageGo to next message
The recipe is normally around 1/2" from the roof skin at most, and at max 1" from the pillars for the main hoop. And then similar for the rest. Common to stitch a plate between the A pillars and the cage too.
Thats from my observation.
Go buy the CAMS manual, and look at the homologated cage designs (and hopefully dont destroy that section with coffee like i did to my 03 manual)
studman
On Probation
Charnwood
March 2005
Re: AE86 Rollcage specifications Fri, 15 April 2005 04:36 Go to previous messageGo to next message
ask da same kwestion twice for double da responses hahahaha.
just use pool noodles from da local toy store, good padding for ya head
Rallystanza
Re: AE86 Rollcage specifications Fri, 15 April 2005 05:23 Go to previous messageGo to next message
studman wrote on Fri, 15 April 2005 14:36
Sickest ov teh maddist,
Dick head,
With the roll cages i have seen in proper rally car and the proper designs, The cage is most efficient in roll over protection when the cage is as close the frame of the car (i.e. pillars) or even connected to these integral frame/chassis components.
So generally speaking, make the cage as close to the edges of the car as you can.
Jezza
[Updated on: Fri, 15 April 2005 05:29]
Rex_Kelway
Re: AE86 Rollcage specifications Fri, 15 April 2005 05:53 Go to previous messageGo to next message
Rex believe the idea for the gap between the pillars and the cage is to sort of isolate the cage from any initial impact.
Imagine...
BANG!!!
The car takes a whack on the side around, mmmm, say the b-pillar.
If the cage is against the pillar then it too will buckle from the initial impact, Not to mention stopping quicker and upping the decelleration force.
Whereas if the cage is a given distance then the impact is dispersed over time given the greater distance in can absorb the impact over so 1 the cage see's less force and is not not damaged by the first impact
If yer get what Rex means
Rex is real eloquent or whatever.
[Updated on: Fri, 15 April 2005 06:06]
Rallystanza
Re: AE86 Rollcage specifications Fri, 15 April 2005 06:56 Go to previous messageGo to next message
Jezza finds himself in a state of agreeance with Mr. Rex Kelway and has also discovered upon further inspection of his own here roll cage that Rex has shown some validity in his point of view.
Another thing that Jezza has indeed put into thinking is that perhaps the person constucting the said rollover protection system must determine his own choice of design, considering all of the above options proposed to him.
Jezza passes on his regards and hopes that this thread may be of assistance to the resultant roll cage......
takai
Re: AE86 Rollcage specifications Fri, 15 April 2005 12:37 Go to previous messageGo to next message
Rex is right, hence the 1/2" gap which i was advocating. As far as i know it the main reason that a lot of rally cars have the A pillars stitched to the cage is because the stitch plate has a LARGE part to play in keeping the A pillar from buckling if you hit a tree with it. Due to the plate being mostly perpindicular to the pillar the stress is spread out across the plate, and then finally across the cage itself.
It is somewhat different for track use.
Johnny
Sydney, OZ
Re: AE86 Rollcage specifications Fri, 15 April 2005 12:58 Go to previous messageGo to next message
ok, we all know the Cams reg's, and these are design for competition vehicles, but bare in mind for normal road useage, you are not allowed to have the side intrusion bars or bars, regardless of padding, within 60mm of any occupant... that is period! also engineering reports will be needed for rego and that car will become registed as a two seater, if he is fine with this, there will be no prob for either the law or engineers that sign off.... Of course, us lucky bastard's that race get away with this, and I'm still wondering why as the car is much safer than the govern. restrictions, but they deem it unsafe... go figure..
takai
Re: AE86 Rollcage specifications Fri, 15 April 2005 14:02 Go to previous message
Well my 86 went through rego on Tuesday without nary a mention of the cage. The only reference to it was "Has to be a two seater because it has a cage" thats all (i thought the complete lack of rear seat, seatbelts or anything back there would have given that one away).
I am led to believe that one of the reasons they dont like people trundling around on the road with cages is that the damage caused to non caged cars is exponentially larger due to diminshed crumple zones. That and a good cage can make it very hard for SES to cut you out, and actually have a higher head injury rate due to the lack of a helmet (when on the road), and prominence of large metal bars.
Previous Topic:4age 16v sounds terrible after 6000rpm
Next Topic:where the f%$# is the wiper relay???
Current Time: Fri Nov 20 13:52:14 UTC 2026
Total time taken to generate the page: 0.0059971809387207 seconds
