Toymods » Tech & Conversions » KE70: rack and pinion or steering box?
the dayo
KE70: rack and pinion or steering box? Fri, 15 April 2005 05:42 Go to next message
as the post says , just need to know what type of steering.
dave
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 06:12 Go to previous messageGo to next message
all the ke70's i've seen are r&p Smile
Super Jamie
On Probation
North East NSW
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 06:41 Go to previous messageGo to next message
r&p. no you can't bolt the crossmember into any earlier corolla
te71 (aka t18) and every other corolla earlier than ke70 has a recirculating ball steering box
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 06:42 Go to previous messageGo to next message
Jesse on these forums has proved you can put a KE70 xmember with r&P into a T18! Appears to be bolt in conversion..
Makes me wonder why every t18 isn't running a R&P setup now Shocked
[Updated on: Fri, 15 April 2005 06:43]
the dayo
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 07:43 Go to previous messageGo to next message
sweet, i'm picking up a KE70 on the weekend, and am going to put an AE71 crossmember in it so i can can put an A series motoer in it, and i was just making sure
dave
Purple_Beasty
New Zealand
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 11:55 Go to previous messageGo to next message
I have seen a large number of KE70's with steering boxes, all were wagons though. They were all NZ new, not sure on what was sold in Oz.
Callum
Super Jamie
On Probation
North East NSW
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 12:54 Go to previous messageGo to next message
jap spec and wagons are generally wierd
ke70 wagons still had leaves
once i saw a jap ke70 sedan at the wreckers around here. twin headlights, a wierd radiator support panel, aircon and thermofans. it also had jap running gear: little ke30 brakes on the front and a 6" jap diff with 3.909 ratio. that must have been one crappy ke70 to drive
September_Squall
Melbourne, Australia
March 2005
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 15:47 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 15 April 2005 16:42
It's because the driver side engine-to-bellhousing elbow brace would foul on the knuckle where the steering shaft meets the rack in T engine applications.
I'm running 2T-G in KE70 on a TE71 rack fitted with KE70 steering rack; it's all sweet escept for that brace, which I'm running without without problems.
September_Squall
March 2005
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 15:49 Go to previous messageGo to next message
the dayo wrote on Fri, 15 April 2005 17:43
dave
KE70 rack will fit the AE71 crossmember. They may be the same part.
September_Squall
March 2005
Re: KE70: rack and pinion or steering box? Fri, 15 April 2005 15:51 Go to previous message
Purple_Beasty wrote on Fri, 15 April 2005 21:55
Callum
KE70s in some markets are sold with recirculating ball steering. Not sure why, pretty sure they'd be the earliest production runs and mostly Japanese production (as I believe NZ cars would be, no local production plant as with AMI in Australia). Pretty sure no AMI-manufactured KE70s were ever fitted with steering boxes.
Previous Topic:MA61 Camber Adjustable Rear Cross-member
Next Topic:ae86 heater core replacement
Current Time: Sat Nov 21 09:06:08 UTC 2026
Total time taken to generate the page: 0.0059499740600586 seconds
