Toymods » Tech & Conversions » difference between 1G-GTE & 1G-GEU
ndgcpr
Pine Rivers QLD
April 2005
difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 10:03 Go to next message
I am curious to know if anyone knows differences between these two motors.
I know they are both 1988cc EFI DOHC 24-valve 6-cyl. I am also aware that the 1G-GTE is turbo and the 1G-GEU is not. but besides that i know nothing. Will the both use the same gear box, engine mounts and bottom end (like can i swap 1G-GTE heads and all the turbo gear onto a 1G-GEU and swap the ECU and it will run)?
Re: difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 10:32 Go to previous messageGo to next message
Compression ratio will be lower in the 1ggte, and even lower in the 1ggze.
Cams will probably vary between the motors too.
As could intake/exhaust manifolds.
Apart from that, all the same.
brett_celicacoupe
townsville NQLD
Re: difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 11:20 Go to previous messageGo to next message
read the toymods articles section
it explains how the codes work
T stands for turbo etc.
brett
Bananaman
Strathfield / Sydney
Re: difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 13:35 Go to previous messageGo to next message
He clearly knows that, i think he wants more specifics..
joecoolmk2
Re: difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 13:40 Go to previous messageGo to next message
specifically read the tech notes! Laughing
ok, the cams will be different, the comp. ratio is different as a result of the different heahds as wells as the different pistons.
ndgcpr
Pine Rivers QLD
April 2005
Re: difference between 1G-GTE & 1G-GEU Fri, 15 April 2005 23:35 Go to previous messageGo to next message
ok the main reason i wish to know this is because i can most probably get my hands on a 1G-GTE motor with an unwell bottom. can i just drop most of the 1G-GTE onto the top of my 1G-GEU, like cams ect and it will run fine??? Because compression is govened by the heads arn't they? and maybe the pistons.
Re: difference between 1G-GTE & 1G-GEU Sat, 16 April 2005 01:46 Go to previous message
ndgcpr wrote on Sat, 16 April 2005 07:35
Compression is goverend by the pistons.
To run the 1ggte properly, you'll need the 1ggte ecu.
Previous Topic:AE86 Rollcage specifications
Next Topic:MA61 Camber Adjustable Rear Cross-member
Current Time: Fri Nov 20 08:29:19 UTC 2026
Total time taken to generate the page: 0.0080370903015137 seconds
